Wtb 2001 abs module
Wtb 2001 abs module
Anyone parting out a 2001 m6 ws6 with 3 channel abs. I would like to buy from you the abs module or if anyone has one off a 2001 laying around please let me know. Shipped to texas please.
Thanks!!!
Thanks!!!
Well found this off of place that rebuilds abs modules just in case anyone else is having abs inop/low trac trouble...
"Is your vehicle having ABS problems? We can offer you a solution!!!
Here are the most common symptoms that let you know that the ABS/EBCM has failed or is failing...
•ABS PUMP ALWAYS RUNNING
•NO COMMUNICATION
•RELAY CODES
•ABS LIGHT ON OR COMING ON INTERMITTENTLY
•WHEEL SPEED SENSOR CODES
•CODE... C0265 (ABS MODULE FAILURE)
•CODE... C0267 (ABS PUMP RUNNING CONSTANTLY)
•CODE... C0268 (SHORTED OR OPEN ABS PUMP CIRCUIT)"
•NO COMMUNICATION
•RELAY CODES
