pulling the carrier out of a dana 60
Anyone had to do this? I cannot get mine out. I turned the carrier adjuster nuts as much as I could. They look to be about seated almost fully. I cannot get them to turn anymore, I think the threads might be gunked up? The carrier looks and feels like its going to fall out, but it just wont. Ive tried prying. Do I need a case spreader? Any help would be appreciated. Thank you.
nobody has ever changed gears out on a dana 60? I fully seated the adjuster nuts, they will not turn anymore. The carrier looks and feels like its going to fall out. Ive been prying like crazy, nothing...
At home trick. You might need a friend. Use and old t-shirt and jam it between the ring gear and pinion gear. Have a friend turn the yoke, and the shirt will get sucked into the gears. It will pop the carrier right out.
LS1Tech Premium Sponsor
If the rear is a Strange S60 then the adjusters are threaded and should be able to be backed off toward the outsides far enough to let the diff/ring gear fall out. No need for as case spreader. An old school Dana rear will need a case spreader. You did pull the axles out correct?
thanks for all the replies fellas. It is a strange s60 and its a long story. Basically, the passenger side carrier bearing destroyed itself somehow and threw metal shavings throughout the pumpkin. I was able to get the rings seated into the housing enough to get the carrier out, but now I cannot get the rings back in because the threads are screwed up. I dont know if anyone sells a thread chaser/tap that big, but as of right now I have an empty s60 and a non functioning car :/. Im going to call Strange today and talk to them about my issue and see what could be done. Any advice would be greatly appreciated.
Here's a thread of a guy that had a bearing go bad in his S60 too. I think Strange ultimately took care of it.
https://ls1tech.com/forums/gears-axl...-s60-down.html
Strange told me to try a thread file. Tried this tool last night which is actually better for internal threads than a file. Im going to call them again today and see what they say.
