Rear End Swap
Old 12-10-2014, 04:40 PM
1995_maro_z's Avatar
Default Rear End Swap
My rear end is pretty noisy. I am trying to find out what my options are in fixing it. Should I rebuild the diff, find a used 10 bolt, or what? From what information I have been able to find, I believe that my cheapest route will be to find a used 10 bolt, and cheap is waht i need right now lol That being said, what specific fourth gen 10 bolts will be a direct swap for my 1994 A4 z28? Also, would I need any special tools or anything like that to swap the rear end out? Could someone possibly direct me towards a write up on a rear end swap? I couldn't find one. Thanks!
Old 12-10-2014, 06:37 PM
LS1Tech Premium Sponsor
ssvert99's Avatar
What rearend you pick will be determined by what abs system you have, and what gear ratio you want. Any rearend from 93 through 02 years will fit, but gears and brake systems are the biggest differences.
Old 12-10-2014, 06:44 PM
LFSADRG's Avatar
https://ls1tech.com/forums/eastern-c...ale-3-73s.html
Old 12-10-2014, 06:46 PM
FirstYrLS1Z's Avatar
1994-1997 3 channel ABS.
Some 1995-1997 rears had 4 channel ABS & TC,so electronics & hydraulics of those would not be compatible.
Old 12-10-2014, 06:50 PM
https://ls1tech.com/forums/gears-axl...diff-swap.html
Old 12-10-2014, 10:05 PM
Right now my car has 2.73's, but i am not gonna be picky. I'll take what i can find local and cheap as far as gearing goes, just definitely not lower than 3.42's (A4 and pretty much 100% downtown Indianapolis driving).
Just to clarify, any 94-97 rear end with 3 channel abs will be a direct replacement? Also, how can i tell if a rear end is three channel or four channel? did the four channel ones come out of cars that had traction control? And that link is very helpful!
Old 12-10-2014, 11:02 PM
94-97 3 channel ABS(only) has a sensor on top of rear end housing. 95-97 4 channel ABS & TC(traction control) has a sensor at each axles backing plate. No,you cannot convert a 4 channel rear end to work in your 3 channel vehicle. (answering before you ask)
Old 12-11-2014, 09:26 AM
Alright, thanks!
Old 12-11-2014, 04:13 PM
Sorry if this is a stupid question, but where is the axle backing plate? Also, do 4 channel ones have the sensors on the top of the housing and on the axle backing plates or can I just use the top of the rear end housing as my easy way to distinguish between the two? Example, this one is 3 channel right? http://indianapolis.craigslist.org/pts/4745019405.html
And this one would be four channel? http://muncie.craigslist.org/for/4712691082.html
Old 12-11-2014, 05:21 PM
links don't work !
3 channel has sensor on top.
4 channel does not have sensor on top.
backing plates:at ends of rearend housing,what caliper and e-brake are mounted to.
Old 12-11-2014, 06:21 PM
links don't work !
Alright, thanks a ton! You have been very helpful and informative! Just a few more questions haha What are some problems or things I should check for when buying a used 10 bolt that is out of the car (or even on that is in a car at a junk yard or something)? And what would you say is a decent price for a used one in decent shape?
Old 12-11-2014, 07:02 PM
oily housing ends and brake area indicating potentially to be replaced axle seals. oily pinion housing area indicating potentially to be replaced pinion seal. a loose pinion,up & down and/or in & out. remove cover and look for broken pieces or if cover already removed,broken parts. gear wear. if Auburn,cone wear. even if everything looks good,noise won't be evident until running in car. 6 speeds/M6/3.42 more abused than auto/A4/2.73/3.23
the last 3 I sold were 3.42 4 channels for 125,125,100. they typically go for much more than that.
Old 12-11-2014, 07:13 PM
You said "if auburn". How can I tell if it is auburn or torsen?
Old 12-11-2014, 07:55 PM
Torsen
Auburns
Old 12-11-2014, 09:02 PM
Torsen
Auburns
Perfect! haha thanks!
Old 12-12-2014, 03:11 PM
UPDATE!!! I was looking throught the service records that came in te glove box of my car and I saw that at 80,000 miles, (the car has 94,000 now) the rear end was serviced and the shop put 70w140 (might have been 75w140) fluid in the rear end and replaced the pinion seal. Isn't the rear end supposed to have 75w90...? Could that cause mine to be noisy? The service thing didn't mention any kind of additive either. If mine is a limited slip (I have clue if it is I just know that my car is a gu2 car) shouldn't it have some kind of gm limited slip additive?
Old 12-12-2014, 04:13 PM
Replacing the pinion seal,(IF,IF,IF the pinion nut was not torqued to specs/returned to it's exact original position) can cause gear noise as the pinion depth and lash have very slightly changed.
The most common gear oils are 75W-90,80W-90,75W-140,85W-140 and I don't hesitate to use any of them.
94 Z28 would have an Auburn 'posi' 2 series because of the GU2(2.73) you mentioned.
Old 12-12-2014, 04:41 PM
dailydriver's Avatar
Yes, if anything, the 75W-140 would have made a noisy ring and pinion a little quieter over 75W-90.
But IF they did not put in 4 ounces of a limited slip friction modifier (even if the gear oil they put in claimed to already have the FM in it), with the Auburn diff which is likely in your axle (given that the previous owner did not swap it out for a Torsen T2/Eaton Truetrac/etc.), that could cause some noises.
Old 12-12-2014, 05:10 PM
Alright haha I just wanted to make sure (and I was secretly hoping there would be a simple reason why my rear end is noisy) lol So since I have an auburn posi, does that mean that I don't need any kind of additive?
Old 12-14-2014, 05:53 PM
An Auburn diff ABSOLUTELY needs the limited slip friction modifier additive!
If it is not added, it will lock up quicker out of turns, BUT, it will also make horrific noises, especially when turning at slow speeds in parking lots/etc., and it WILL wear VERY quickly, unless it is ONLY driven in a straight line.
Quick Reply: Rear End Swap
