Differential advice
Differential advice
I own a 2000 NHRA Pontiac Firebird Trans Am LS1, recently the differential had been leaking and making a noise. Everyone I've had look at it tells me I need a new one. Where would be the best website to go to order one? I'm looking for 3.73 ratio or 4.10 ratio. I don't know the difference between higher or lower numerical carriers. I also don't know how many teeth to go with.
LS1Tech Sponsor
12 Bolt
http://shop.brutespeed.com/Moser-9-I...c-Truetrac.htm
http://shop.brutespeed.com/Moser-9-I...h-Wavetrac.htm
9 Inch
Here are the Moser 12 bolt and 9 inch rears that I sell. Give me a call if you have any questions, or send me an e-mail. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
I just recently bought the car so I'm still learning about it. Its a 6-Speed with a stage 2 clutch making roughly 400hp. I'm not sure on the torque. I would just like to have a nice ride with the ability to kick the *** end out if I want. Whatever I get I need to know its going to handle the torque and power.
Stay away from a 10 bolt then, unless your adding more hp to it in the future any of the 3 should do you fine. 12 bolt is probably a cheaper option. Don't get a spool, some of the less expensive rears come with spools that are tough as nails but not good on the street. Im not experienced with different setups but I love my strange 12 bolt.
I'm sure that would do great, should be pretty similar feel to stock. I went with this cause its supposed to take a beating and last forever, I like it but the posi might ride better.
http://www.summitracing.com/parts/dtl-914a575/overview/
LS1Tech Sponsor
If your car has ABS and traction control, the Trac-Loc is a good way to go. You can't go with the Trac-Loc if you have just ABS, in which case I'd go with the Truetrac. Bob
__________________
LS1Tech Sponsor
Nothing to worry about, it will be back up shortly. Bob
__________________
