Rear Driveshaft Loop..........anyone...?
I remember seeing somewhere, a long time ago, a car with two Driveshaft loops. Front and Rear loops.
I just bought a BMR tunnell brace mounted torque arm with a front DS loop.
But this does nothing if the DS breaks just behind that front loop. The car can still be catapulted if it breaks at that spot and the DS drops to the ground.
I want another loop about 6" forward of the rear u-joint.......this way no matter where the DS breaks the shaft cannot hit the ground. If it breaks anywhere forward of the rear loop or behind the front loop....the middle section between both loops....both pieces of the shaft will be supported by the loops.
I assume this is custom made stuff only...
Anyone know of a rear loop sold somewhere...?
Carl
I heard when a carbon shaft brakes it brooms out, could do damage but nowhere near what metal on metal would do. The price of the carbon shaft would be nothing compared to the price and time to replace brake lines, suspension, under body work that the metal shaft would clearly do. Heard the safely loops help but more than likely will just rip it right off with metal shaft.
I highly doubt it would do anything, but damage is damage so strength could be compromised. @1300rwhp I woundnt be buying anything but a carbon fiber driveshaft, stuffs going to break, if it's the driveshaft sure hope it aint metal.
I have broken 2 shafts since I owned my car from 1998 when I bought it new.
First time (factory stock aluminum) was literally driving 5mph through a parking lot...it just broke and heard.....clunk, bang, ding, bam.....I stopped and looked under the car and saw it dragging on the ground.
The second time (steel shaft) was at 150mph.....I heard a quick smack like a hammer hitting a metal table and then perfect silence. I just rolled to a stop. The shaft broke about 6" from the rear u-joint. The rest of the shaft just slid out of the tail house of the transmission and fell onto the road. Luckily it didn't somehow get caught up in something on its way out and puncture a hole through the car or lift it up. It went onto the road and out the rear clean.....
The little 6" piece that stayed attached to the rear-end just spun around and there was a couple little ding marks from where it made contact a couple times. Nothing bad at all.
I'm just scared of the break happening 10"-16" from the front u-joint....because then the shaft will drop straight down and hit the ground....possibly causing a catapult situation.
I'll definitely look into carbon fiber shafts. I'm waiting to hear from PST on their recommendation for me.
Like Carl mentioned you see this kind of driveshaft safety loop manufactured for nine inches. I've never seen one for a stamped style housing all though it may be out there just not a huge demand for it.
He also brings up a good point on the driveshaft being carbonfiber. With PST you can purchase a warranty and get a lifetime warranty on it. I've had mine for a few years now and driven on the street and still shows no sign of rock chips.
With any driveshaft especially a carbon one make sure not to jack up your vehicle and allow the driveshaft to support the rear end on the driveshat loop or exhaust. It is a killer on any material driveshaft.
What about jacking up one corner or one whole side to change a flat tire..?
If you let the rear end hang no matter how you raise it into the air you risk letting your driveshaft hit the safety loop or exhaust. The bigger the shaft the bigger the risk.
