Best Rear Gear
Best Rear Gear
I'm at the point were it is time to re-gear my car but not sure what ratio to go with. I have a 383 lt1 w/cc503 cam and m6 trans. will be on 28-10.5-15 (strip) and 285-35-19 which equals 27-11.5-19 (street). I am torn between 3.73 and 4.10 if you let me know which you feel would be better and most important why with a valid reason it would be greatly helpful.
4.10 if street/strip car, because there is no reason whatsoever to have a higher gear unless you're somehow out mphing the 4.10.
4.30 even better.. Or 4.56
Absolutely nothing wrong with a 12 bolt, whatsoever. At that price id hold out. the strange 60/ 12 bolt comes in right around 2200 USD brand new. I suggest avoiding a differential.
Seeing it's an m6 I'd opt for the s60.
It's not a matter of IF you'll break the stock rear in a clutch car. Only a when, and usually it's sooner than later.
