Stock pinion yoke replacement
98 A4 Trans am stock rear\stock DS
Where can I find a stock pinion yoke replacement for my car? I've been looking on sites like moser\spicer\etc but I'm not sure which is the correct one for my car. Also if I were to get a new pinion yoke would I still use the 1st design pinion seal?
Thanks!
Thanks!
I went through this same issue a few weeks ago. I have a 2000 SS however..... But anyways I have a rear pinion seal leak that just wouldn't stop. I replaced the pinion seal twice with brand new GM seals and both times the leak returned within a few hundred miles.
In the end I went to the dealer and ordered a new yoke assembly. For $102 I got a brand new yoke, U-Joint straps, pinion seal and pinion nut. Everything was the new design. Installed in all and my car hasn't leaked a drop since. Just go to the dealer and order a yoke and it should come with everything you need all in one box.
