Ford 9 inch rear end build?
Hey guys looking to build a 9 inch rear now that I have drag radials that hook real well in my m6 cammed Camaro that makes 450 to the wheels looking to do my heads as well so I know something is going to break. Can someone give me some insight as to a parts list of what I'll need. Obviously the housing, axles, center section but what else would I need? Thanks
We offer multiple options for the DIY builder. You can purchase just a fabricated core, housing ends, and F-Body specific bracket kit. As well as the same torque arm we use for F-Bodys.
Or you could purchase one of our housing and torque arm packages for $1699 shipped. It comes with a housing at any width, housing ends for your particular brakes already installed, all F-Body specific brackets already welded in place, torque arm, and crossmember.
Much easier and cheaper than trying to build it yourself, just add your axles and center section.
Originally Posted by The Cartel
Not to hijack... but how much can you narrow the housings for wider wheels/tires without having to mini tub a 99 Trans am?
Narrowing your housing is doing nothing more than moving the center line closer to the right line. It does not change the chassis what so ever, what does require mini tub is wider wheels and tires over combinations that will fit with in the stock wheel tubs. If you want to go to a 12" wide wheel plan on mini tubing your vehicle, a 10" wheel will work just fine and the most common narrowed combination is -3 per side.
Hope that helps.
