How much interest is there in an 8.8 housing modded to fit Fbodies?
Old 09-15-2004, 10:09 AM
Gripenfelter's Avatar
Default How much interest is there in an 8.8 housing modded to fit Fbodies?
I was about to order a rearend from Extreme Chassis until I heard about all their problems.
I scoped out a guy in my own town that will do it fairly cheap. He's been building rearends for 25+ yrs.
I'm wondering if there's any interest in getting just the 8.8" housing already modified for the spring perches, LCA brackets, and Torque Arm mount? In other words a complete ready to bolt in housing that you would have to fill with your axles and center section.
How much would you pay for something like this? Just the housing I mean.
He's not cheaper for axles or center sections so that part would be upto the customer but the hard stuff would already be done and Mustang 8.8" stuff is relatively cheap.
If there is enough interest I'll contact the Admin of this forum for advertising purposes before going forward with this venture.
P.S. I'm a long time member of CamaroZ28.com with over 6000 posts but I just lurk here.
Old 09-15-2004, 10:35 AM
SSCamaro99_3's Avatar
Depending on price it could be a nice alternative.
Old 09-15-2004, 11:55 AM
cam
cam's Avatar
I already make them. I have had a very busy summer and have not had time to ramp up production but things are loosening up now allowing me the time to do so. Heres a link to my original post on it
https://ls1tech.com/forums/showthrea...&highlight=8.8
I have a jig all ready to go.
Old 09-15-2004, 03:50 PM
99WS6Formula's Avatar
I think someone could sell quite a few if they were modified correctly w/ no problems w/ the welds or fitment issues. I'm a little learry about sending someone a large amount of money for one now since I'm one of the guys that craig tried to screw out of $2k
Old 09-15-2004, 07:57 PM
ohhiitznik's Avatar
I'd be interested, Just the housing with the axle tubes, torque arm mount and spring mounts and what not, then yo ubuy your spline axles, your gear, everything for it. Just make it bolt in, then you fill it up with the internals. I'd drop a good 750-1000 on a good housing.
Old 09-16-2004, 10:35 AM
Sounds reasonable.
Old 09-16-2004, 11:05 AM
Turo's Avatar
im interested also, if the price is right. ive been looking for a 3-channel aftermarket alernative to teh 12-bolt (KEEPING the abs)
Old 09-16-2004, 09:18 PM
frcefed98's Avatar
I'd be interested in this too, 700 sounds fair
Old 09-16-2004, 11:03 PM
matts22's Avatar
I'd be interested, but I unless my rear goes out, I won't be buying a replacement for awhile. However, if all goes well and they can be built strong with no whine, I'd definately consider it.
Old 09-17-2004, 11:40 AM
TRex's Avatar
I think $700 sounds a little high, given that a 9 inch housing from Moser is $585.
Old 09-17-2004, 10:51 PM
cam
cam's Avatar
$585 from Moser gets you a generic 12 bolt housing with leaf spring perches only... not a direct bolt in which costs $850.00 and comes with the lousy four bolt torque arm bracket and no provison for ABS or TCS.
Old 09-30-2004, 03:27 PM
LT99LS1's Avatar
Are you into production of these yet?
Old 09-30-2004, 04:38 PM
LT99LS1's Avatar
Sent pm back.
Old 09-30-2004, 09:37 PM
cam
cam's Avatar
Who were you trying to PM?
Old 09-30-2004, 10:55 PM
LT99LS1's Avatar
Gripenfilter sent me a pm after I posted in this thread. But I would be intrested in seeing info on any 8.8 stuff you make for the Fbody.
Old 10-01-2004, 08:09 AM
Yes its better to PM me. I hardly check this board. I'm on www.camaroz28.com more.
Old 10-03-2004, 10:30 PM
TRex's Avatar
Straight from the Moser site:
http://www.moserengineering.com/mose...ts.asp?CatID=8
"Housings - 9" Ford Bolt-In"
" PN 7H9FBT GM "F" Body Housing WITH Torque Arm Brkt $585/ea "
Old 10-04-2004, 08:19 AM
cam
cam's Avatar
Haha I guess i should have read where you said 9 inch not 12 bolt My appologies there. I was refering to the 12 bolt bare housing that I just checked on and its actually $590.00 but the bolt in is $850.00.
Old 10-04-2004, 10:09 AM
OWENMUSTANG's Avatar
700.00 sounds fair to me..
if of course, it's been bullit proofed..
