2.73 times
My friend in his A4 02 Z with only an 80 series flowmaster with a 2.1 60' time ran a 14.33 at 3700' elevation. If u correct it to sea level thats about a 13.5, oh yea he trapped at 100.01mph
12.9 best, 1.98 best 60', 8.47 best 1/8th, trap 108.75mph
this is on stock converter, stock 2.73 rear, bald street radials, Ls1 intake, 3750+lbs
mods: lid/midlength headers/dynomouth exhaust/FTRA/HPP3/ASP crank pulley
the 2.73's arent a bad gear as much people think. lower cruising rpm's, but suck from a roll. Good gas mileage and easier on the rear end when you start getting into high power levels
what was the rest of your setup?
Have not run the car since adding the spooled 9" with 3.50 gears, better valve springs with home ported heads, no more cats and weight reduction and a big FMIC for the blower. Hoping it runs mid 10's around 130..
2.73 gears are actually pretty good through the 1/8th. After a 100mph or so once in 3rd gear, then they need a lot of midrange power to pull them strongly.
Back when the car was NA, I ran low 12's at mid 113mph with home ported heads and a hotcam. I would only use 1st and 2nd gear locking the converter in 2nd around 5000rpm to run up to about 6500rpm through the traps and pull close to 114mph in 2nd gear.
My quickest times are in my sig car went 13.12 at 104mph with nothing but aftermarket lid every thing else was bone stock and weight was 3750lbs hope to get it the 11s na when I get home from Iraq with the 2.73's.
Check the sig...If I'da shucked the passenger seat and the extra 30 lbs of fuel I
had, 11.30s all motor are in the bag. Like SJH said, the car only starts to struggle after the 1/8th.
I stopped telling people about the 2.73s. They give me the BS look
