any one running the BMR extreme torque arm on after market rear?
7 Second Club
i have read that this TA on a 12 bolt moser is a bad idea...i just want to know if any one is having problems with it at all on any rear besides the stock 10 bolt... thanks
What exactly is it you've heard about running those two together? I've been running a Moser 12 bolt and BMR Trac Pak for a while now with no problems. Only known problem I'm aware of is the bolts backing out over time. Instead of the supplied bolts I used 8.8 bolts with longer threads and some loctite.
Chad
Chad
7 Second Club
Chad
Chad
thanks.
Tyler
Originally Posted by ty_ty13
where'd you get the 8.8 bolts? have you ever checked the bolts and them be loose at all? the bolts backing out is the only thing ive heard...
thanks.
Tyler
thanks.
Tyler
Chad
LS1TECH Sponsor
Been running the BMR track pack and a Moser 12 bolt for 3 years. I have never had the bolts loosen up. Red loctite took care of that. Just checked them again whrn I had the trans out and all was fine.
7 Second Club
i wonder how come BMR has that warning on there Xtreme duty torque arm...isn't moser, QA1 and BMR one of the same companies...same owner or something...
weird....
weird....
No, BMR Moser and HAL (makers of the QA1s) are not the same company. We use the BMR X-Treme Torque Arm and a KTRE 12-bolt with no problems. Our bolts have not backed out either.
