Am I mistaken?
Going taller/numericly higher multiplies torque @ the wheels. It's sort of like gears on a bicycle...You have it in a low gear to climb hills (torque), and then a shorter gear for speed. Taller gearing will make a car quicker (ET's). Fast is usually the term associated with trap speed. I hope this helps...
Let me explain that a little differently. A numericaly higher gear ratio allows the engine to accelerate faster under a given load than a smaller gear. At each shift point you reach, the car will be moving slower, but you will reach each shift point sooner.
14 Second Truck Club
Shorter gears are higher numerically, and taller gears are lower numerically. Shorter gears are good over a shorter distance, that is the easiest way to remember it. Also, people will say the rear is geared "low" and what they mean is higher numerical (4.10, 4.56).
its not that it puts torque at the wheels...
look at it this way its a ratio 3.42(rotations):1(rotation)
3.42 turns of the axles/wheels(?) to 1 rotation of the Driveshaft
so by getting 4.10's your car travels further than 3.42's with one rotation of the D/S hope that helps
oh i was told the other way around...by a few people actually...but hey they could be wrong. Makes more sense
if the wheels would trun more for 1 turn of the D/S that would mean they spin faster or more because of the the ratio
the way your showing it is that the driveshaft would haveta truun faster to make the gears quicker out of the hole
