downshifted into 2nd at 80mph?!!
i already posted this on the manual trans forum, but wanted to get some more opinions here,
i was gowing driving down the highway at 75-80mh and wanted to downshift into 4th, instead it got into 2nd by mistake, rpms jumped up and i pushed the clutch in less than a second when i realised it, after that i feel little vibration when driving. i don't know if it's coming from the rear end or what, i don't think anything happened to the motor. so what would you guys think went wrong, did i break something?
btw, i have an 8.8" rear end with 4.10s, with a strong drive shaft..
also, the LOW TRAC light comes on from time to time, and sometimes the ABS INOP and ASR lights come on at the same time, when i push the brakes it feels kind of weird when the LOW TRAC light comes on?
so what would you guys think hapened?
thanks,
thanks,
You might want to check out your rear suspension to see if something is cracked or came loose. One time I hit 2nd instead of 4th when I had it nailed, and I snapped both my rear shocks in half at the shaft. I have all Hotchkis suspension parts and a Spohn TA, so I figure that since those parts are so strong, all the energy went to the shocks. If you have stock parts you may have broke something. I imagine that could cause vibration. If you broke the rearend I would think you would be able to hear that.
one night a while back i had been drinkin to much and decided to get into it gettin onto the highway on the on-ramp and i went 2 to 3 and back to 2, rpm's jumped rear-end skipped. and it seemed fine for the rest of my drive on the highway makin ga very slighty noise, so once i got of the highway it started to CLUNK like crazy. well about half a mile later i was stranded on the side of the road with a stripped pinion gear....stupid 4.10's.......erg, stupid me =/
Well, I almost hate to admit it, but I have done that a few times myself (damn auto's always want to race from a 75 punch with out giving you a chance to downshift and 4th is hard to find from 6th in a hurry). Only I had a stock rear with 3.42's... only thing I hurt was one intake pushrod (bent not broken), which ran like that for about another 30K miles before I decided to pull the valve covers and check them.
I grabbed 2nd at 88 mph while racing a turbo 5.0 at the track, but as of today, I don't notice any differences by either sounds or SOTP feel.
Originally Posted by 1ScrudeDude
Was there any sounds your engine made that tipped you off? Decrease in power?
I did the same thing, had it wide open and hit second, the rear jumped around for a second before I hit the clutch. The rear lasted about 3 more months, around 4000 miles. was making a little noise before but it got a lot worse. After I could hear it over the stereo I parked it yesterday and started driving my 78z with a t56. Out of the blue it started vibrating when downshifting and vibrates from 1st thru 4th when accell. goes away when I push the clutch in. Feels like something sycro in the trans, when you are rolling and push into 1st you can feel the sycros speeding something up before you put it all the way into gear. Whatever its meshing is vibrating like hell. It stops in 5th and 6th. Anyone know what that deal is? Thanks
Check for the torque arm looking like this one.
http://www.exoticperformanceplus.com...php?service=58 Bob
