noise from rearend?
Old 03-26-2005, 10:03 PM
nyg215's Avatar
Angry noise from rearend?
i have a wierd noise coming from my rearend when ever i let off the gas and let it coast but soon as i give t a little gas it goes away what do u think? i dont have new gears in the rearend but i did try and have them installed but the ***** that got the gears for me from a dealer got 2 carrier gear instead of my 3 carrier so they took everything apart and then just put all the stock stuff back do u think they could have not put enough fluid in the rearend? need help please!!!!! this is the most annoying sound ever!!
Old 03-26-2005, 10:10 PM
SStheBest's Avatar
possibly....was it doing this before u took it to the dealer?
Old 03-26-2005, 10:16 PM
nyg215's Avatar
no never
Old 03-26-2005, 11:27 PM
TNormZ28's Avatar
Could be they didn't do the crush sleeve right, and put the pinion too tight or too loose. Or maybe they put the wrong shims back there. Only way to know is to check it.
Old 03-26-2005, 11:33 PM
shiznit's Avatar
Mine is doing the same thing. I'm having someone look at it on monday.
Old 03-27-2005, 12:09 AM
SgtB's Avatar
Most likely there is too much backlash between the ring and pinion. If I remember correctly its .010-.020??? Someone please correct that if I am wrong.
Old 03-27-2005, 01:38 AM
TNormZ28's Avatar
I set mine up at 6 or 7 with a good pattern. No whine.
Old 03-27-2005, 05:20 AM
Nate_Taufer's Avatar
this may sound stupid, but check your lugnut torque. i have seen it happen a few times.
Nate
Old 03-29-2005, 03:51 AM
z-ya's Avatar
classic sign of pinon bearing failure,is it like a whurring sound with the clutch in and a slight vibration?
Old 04-01-2005, 05:41 PM
Scully's Avatar
i had this EXACT problem with my 96 z28 i used to have. check the pinion nut. mine was loose, when i tightened it up the winding went away.
Old 10-02-2005, 08:56 PM
longrange4u's Avatar
Old 10-26-2005, 07:23 PM
ken13400's Avatar
dont forget about the wheel bearings too.
semper fi sgt reynolds
