Strange 12 bolt owners with 3 channel what did your ABS sensor look like?
Finally installed mine tonight, and the only problem I ran into was the ABS sensor. The one on the strange unit was black with just a threaded bolt and nut spun on it. I thought you took that one out and installed the old one from the 10bolt. Well to my surprise the 10 bolt sensor was way smaller. Then we noticed it looked like there was a wire hooked up to the top of the threaded bolt sticking out the top of the what I thought at the time was just and ABS sensor hole plug. I will try to post pics later.. I thought it was also weird the backing plates they put on my Strange have the holes in for the 4 channel sensors. Just figured it was an universal plate. Maybe I got the wrong setup?
My question is short and sweet. Was there a plug attached to your Strange 12bolt ABS sensor that fit into the GM style plug?? I think mine got taken off someplace during shipping, or I got the wrong setup.. Will have to contact LS1speed on Monday, it is eating me right now… Thanks..
Originally Posted by speedo
Ordered it about Feb 15, got it March 9th.
Looks like some downtime for me. There was suppose to be a harness attached to the sensor. It was gone when I got the rearend. I called strange and I have to send mine in. Great so it looks like I have a week wait at least. Kinda upsets me that you shell out 2600$ and then have to wait for a 2$ sensor. I have pics just don't know how to post them.
wrencher
Originally Posted by chief455
mine just had a tiny sensor with about 2" white/black wires hanging out. I spliced them into my wires with new connectors, shrink wrapped and the ABS works fine.
ABS works fine.
Originally Posted by wrencher
Exactly, thats what they all look like. I made a terminal end for my harness & spliced that in to the strange sensor.
ABS works fine.
ABS works fine.
Sent my sensor back in today. Hopfully I get it back soon with some wires attached this time. I just unscrewed the sensor out of the plate and put a stud with a nut in for now so I don't have any downtime. I actually sent the plate with the sensor in it, and had to run back up to the post office 30 mins later to get the base back. Luckly it wasn't picked up yet.
Now that is my next question when I do get the sensor back how do I set the depth?? And what to do with the old ten bolt. I already have good boat anker.
Thanks again
Originally Posted by Fulton 1
With the rear cover off, thread the sensor into the housing until you measure .011" minimum clearance to the reluctor wheel with a feeler gauge, then tighten the jamnut.
Got any idea which wires hook up where? Black to dark, white to white I assume, I should have called Strange, but it is to late now.....
