3.73 gears?
Old 04-27-2005, 03:01 PM
firechicken2k's Avatar
Default 3.73 gears?
i've 2.73 gears right now..
now, if i change to 3.73 gears, what all would have to be done to make sure that everything else 'knows' about the 3.73s and works with them ? will my speedometer work accurately still, for example?
Old 04-27-2005, 04:30 PM
silver02Z's Avatar
As far as the spedo, it'll need to be recalibrated...I had my done by a shop that has HP Tuners..You will need to get gears for a series 2 carrier...
Kevin
Old 04-27-2005, 04:42 PM
BAIN's Avatar
If you have 2.73's I think you have to change to a different carrier as well as gears.
Old 04-28-2005, 02:02 AM
GT Griller's Avatar
Just order the 2 series carier 3.73's and like Silver02Z said have the pcm reprogramed to 3.73's that way ur shift points don't change and ur speedo isn't off.
Old 04-28-2005, 08:35 AM
fivepointseven's Avatar
Where can you order 2 series gears?
Old 04-28-2005, 01:48 PM
GT Griller's Avatar
any of the sponsors that sell gears should have that option. If u don't see it just give them a call specify it.
Old 04-28-2005, 01:53 PM
14 Second Truck Club
mzoomora's Avatar
The 2 series 3.73 gears are fairly common, should have no problem finding them.
Old 04-28-2005, 03:11 PM
Uno99's Avatar
I hust did the swap and used the Richmond "Thick Gear" no need to change carrier.
Old 04-28-2005, 03:40 PM
GT Griller's Avatar
http://www.jegs.com/cgi-bin/ncommerc...87&prmenbr=361
Just go down the page till u see GM 10 bolt and u can see it has different options for carriers.
Old 04-29-2005, 08:50 AM
BBQLS1's Avatar
PCM will need reprogramming. I have heard those hand held ones **** up your computer and will need to be wiped if tune via laptop later. Not good. Use the laptop software.
