Looked on EATONS web says nothing about not useing Synthetic lube?
I was just wondering where everyone herd this from I saw it with my Moser instructions to use the dino lube, but I wanted to research all my options etc... I didn't see it anywhere on there web page about no synthetic lube with there HD limited slip "Posi". Any one know where it came from? Thanks.
Jeff
Jeff
LS1Tech Sponsor
Eaton uses a carbon fiber clutchs in their posi's but I think Moser's 33 spline units use the older clutch material. Eaton uses a bonding agent to hold the carbon fiber to the disc, when in contact with synthetic lube it just falls apart. I would call Moser tomorow and just double check.
I talked to Moser about my 9" full spool and they said dino oil. Why, I dunno. They really couldn't give me a worthwhile answer. Either way I run 1 1/2 qts dino oil, 1qt Lucas additive oil. I figure with that mix I'm safe either way. Quiet either way....decel has a slight whine but its a Moser center section so thats what you get.
I called the eaton powertrain rep and asked him this very Question last year,he told me
that their posi unit would be much louder with synthetic oil and grabby in corners so did
not recomend useing it.When I pressed him on the issue of better protection he said the testing they did with gm did not show any benifit.
Jeff
Jeff
