beefed up 10 bolt??
Old 05-27-2005, 05:20 PM
dave70's Avatar
Default beefed up 10 bolt??
hey guys anyone know a way to beef up our 7.5" 10 bolts? axles are least likley to go first from what i've heard. ring and pinion and diff are what goes 9 out of 10 times so diff cover with preload bolts should help a little. ? anyone know 4 sure? ok what about welding the tubes? that do any good? what about fabing up a brace like a strongback would that help iyo any other ideas sounds like 99% of destruction is caused by the rear flexing (sheared teeth etc.) any ideas? is all this worth it? how much more life would it buy just wanted to see who has tried any of this. i had a 7.5 in a S-10 that lived for wears but that was with an auto and drag raidials. ok just running on now any thoughts ???? later
Old 05-27-2005, 06:09 PM
Hawkcmc's Avatar
People have tried beefing up the rear axle and most have failed, its been proven that it is not worth it. You may get lucky but chances are not in your favor.
CMC
Old 05-27-2005, 06:18 PM
dave70's Avatar
yeah that's what i hear but i was wondering what it is they did and what the results were?
Old 05-28-2005, 07:10 AM
Viper's Avatar
I've got a 10-bolt with a T2R, T/A cover, race pinion and preload bolts. Car has lived through H/C at 400HP.
Old 05-28-2005, 07:14 AM
cablebandit's Avatar
10 bolt on a a4 is no problem. What kills them is wheel hop!!!! Usually gets the posi. I am still on a 10 bolt and only two times I had probs was...you guessed it...wheel hop in burnout and got the posi.
Old 05-28-2005, 08:07 AM
Blacker's Avatar
Even the mighty 9" can be broken with wheel hop. The 10-Bolt, that I had, lasted awhile and the posi was the limiting factor. The spider gears were cracked and the 3.42 gears are still good.
Old 05-28-2005, 12:06 PM
tomss99's Avatar
yup.. its always the diff that goes... my ring and pinion are fine in my ten bolt but the spider gears in the diff blew.... so im in the process of putting in a eaton
Old 05-29-2005, 11:11 PM
dave70's Avatar
has anyone tried bracing up the rear or welding the tubes? seems like that would help even more than a cover yith preload bolts. and i know thew make braces for 9" that make them a lot stronger.
Old 05-30-2005, 08:37 PM
01FbTaWs6's Avatar
a buddy of mine has a 10 bolt in his 72 nova, and it holds up just fine. he pulls the wheels hard, and comes off the line with a 400 shot. All he has is welded tubes and a cover, with an eaton posi unit. You couldnt put a brace on the gm 10 bolt because the cover is in the back, they make them for 9 inches because the whole center section, or pumkin unbolts from the front, anyways, his is fine, and is 2 seasons old, but doesnt have any wheel hop. Wheel hop is the killer. Also has moser axles.
Old 05-30-2005, 08:43 PM
02SOMWS6's Avatar
You could always change your axles and go with a spool
Old 05-30-2005, 10:21 PM
WhiteyLS1's Avatar
im not even gonna bother with mine anymore. ive tried. they're junk.
Old 05-30-2005, 10:24 PM
Hardtop00SS's Avatar
beefing up 10 bolt = throwing money in a fire. Save the money for a 12 bolt
Old 06-03-2005, 09:39 AM
NOBR8KSS's Avatar
Some GM cars have the 8.5" 10-bolt which is pretty durable. The 7.5" or 7.625" 10-bolt sissy-chunks are the weak ones.
Quick Reply: beefed up 10 bolt??
