any body with 4:10's and a bottle?
Well just got done doing a search, and i didnt come up with anything really...The question i had was in an M6....can you run 4:10's and a 100 shot?? I know you could run out of gear at the end of the track but still, The bottle would only be used every once in a while, since the car is on the street 90% of the time...hince the 4:10's...if i was at the track more i would go smaller gear and bigger shot...
thanks for your responces
Oh and if anybody here is doing this how do you like it??
Originally Posted by SUX2BU
when my car was an M6 i had 4.10's and a wet 150 shot. I LOVED it. I was about to go to 4.30's but then went auto and kept the 4.10's.
Its just that people always say youll run out of gearing?? Did it happen to you?
Originally Posted by mellowyellow
I have 4.10's and a bottle.................of sprite does that count ? J/K I'm actually interested in the responses this gets .May put a bottle for real on soon..
What other mods do you have? I think on a 26" tire if you are trapping 120 it would be about 6400 rpm. My car has 4.10's on a 100 shot I trap around 130, but I use a 28" tire at the track.
Originally Posted by blue2000Z28
Really?? Did you drive your car on the street as much?? Any info you have would be very helpful...IE, Did you run out of gearing, I am asumming it was fast as **** with the 4:10's and bottle ??
never ran out of gear. ran a best of 10.60 @ 130 on the hose.
in my car with 26's at 6800 it would cross the traps at 128. put on some 28's and your up to 138. 10 mph may not sound like alot but thats ALOT of mph.
DAMN..I really didnt know there was that much difference in switching. I will run the car on the streets so is there going to be as big of a difference on traction as well as the mph on the street??
I am really new to the tire sceen. I always thought a 26 would be fine but as said alot, you learn something new everyday
Originally Posted by dug
26/28*4.10=3.81
Switching to a 28" tire from a 26" tire effectively reduces the 4.10 down to 3.81
WOW, i cant believe that it is that big of a difference. thats amazing..thanks guys
So with a 28 in. tire, could i eaasly run 4:30's and a bottle?? or is that to much?
With my M6 4.11s in the 9" and a 28" tire, it was perfect for the 1/8 and the 1/4. I was crossing the traps at the top of 3rd in the 1/8 and top of 4th in the 1/4. This was with a 6600 rev limit.
It went 10.71 @133 in the 1/4 with a crappy 60' on a 200 shot
I hope this helps.
I hope this helps.
I hope this helps.
I hope this helps.
It does..thanks alot..It looks like when i get the 9in. I am more than likley going to go with something around a 4:30 or something around there, i dont know my options yet. Now the tire on the other had, im not sure on..But all your guys info really helpd me out..thanks a bunch
i do i do...theyre nice...especially with a set of DR's...just hammer it while spraying...the car flies.
im currently running a 26 inch tire with a cam and 150 shot..went 11.4 at 123.
i never ran with the power in my sig, but im gonna most likely switch to a 28 inch tire.
