I think I broke it
Old 10-10-2005, 09:03 PM
GuesDog's Avatar
Default I think I broke it
I have a moser 12 bolt with 4.10's in it in a 99 T/A, when I make a turn right or left doesn't matter the rear makes this cluncking noise, the tranismission is in neautral with the clutch in or out doesn't matter. What is it???
Old 10-10-2005, 09:39 PM
Krab's Avatar
Sounds very similar to when I broke the spider gears in my 10-bolt carrier. Only way to find out is to take the cover off and inspect the internals.
Old 10-10-2005, 10:17 PM
GuesDog's Avatar
The moser has only been in the car for maybe 3 months, and only had 5 passes on it. But I guess thats the way it goes
Old 10-10-2005, 10:25 PM
tim99ws6's Avatar
is it a posi or what?
Old 10-10-2005, 10:35 PM
GuesDog's Avatar
yeah its the eaton posi with 33 spline axels
Old 10-11-2005, 07:47 AM
_HAVOC_'s Avatar
thats why i just ordered mine with a spool, differntials suck! i've broken 4 of them now!
Old 10-11-2005, 08:04 AM
NHRATA01's Avatar
LS1Tech 20 Year Member
Are you sure its not just the sound of the clutches locking and unlocking? My Moser w/33 spline and Eaton 800lb HD posi has made clunking noises since day one, and Moser and Eaton say its expected. It usually only does it when making a left or right turn, ie not just taking a corner, and usually only does it if no throttle is applied.
Old 10-11-2005, 11:48 PM
GuesDog's Avatar
That is pretty much exactly what mine does
Old 10-12-2005, 10:16 AM
ken02ws6's Avatar
Sounds very familiar.. Pull the cover ASAP and I guarentee you it is the spider gears, you will see teeth missing on them. I had the same problem at about 5000 miles and it can do a lot of damage if you continue to drive it like that. I got lucky but I was told that it can cause your axels to twist which will void your axel warrnty if you have one. Again, pull the cover and take a look before you drive it again.
