I Want a 9 Inch, but God Doesn't!
I'm about to drop the major coin and buy a Moser rear axle for my SS. I've been torn between a 12 bolt and a 9 inch for quite some time now, but I like the 9 inch because if I ever want to go all out, ***** to the wall, race only, the 9 inch can be more strongly built than the 12 bolt. So I start investigating...
I want an aluminum center section for weight savings. I'm not even considering the nodular.
I originally would've liked the 35 spline/detroit locker setup...until I drove one! That thing was miserable, and I still like logging street miles with the car. The locker is definitely out, along with a spool (for obvious reasons).
I started looking into posi units, but I don't like putting clutch packs in every year. The car is going to be abused (6k clutch drops at the track, etc), and I want a gear setup that is going to hold up!
...Then I started reading about the Truetrac. Alas! Great street manners, no need to ever replace clutch packs - we have a winner! Or so I thought. I at least wanted a 33 spline setup. No dice! You can only get a Truetrac in a 9inch using a 31 spline setup. No big deal, I'll likely never break the 31 splines anyways.
Guess what? You can't get a Truetrac unit inside of the Aluminum center section.
I'm at my wit's end. I can get a 12 bolt, 33 spline TrueTrac setup, and thats likely what I'll do. I just don't want to spend all this coin and then break the rear end. My buddy is leaving at 6500RPM in a 6spd car like mine, and has literally bent the teeth on his 4.56 gear! I hope I can avoid that problem, as well (I'll be using 4.10s.) His rear end whines terribly on deceleration.
I just wanted to use this thread to vent my frustration in what seems like a never-ending saga to find a 9" that I'll be happy with. I guess it's not going to happen.
Yeah it took me a while to deliberate on what I wanted.
I know people say that a 9 inch is stronger, and it might be, but it's not like you see stories left and right about people breaking 12 bolts. Really, anything is a mass improvement over what you've got, look at it that way...
I ended up going with a basic Strange 12 bolt, eaton posi, 3.90's. We'll see how it does. I really just want to get my car back together and run some good passes, and be solid and driveable.
Same here, it was a complete compromise what I ended up getting (Strange 12-bolt, Eaton Posi, and 4.11s). I originally wanted a 9" with a True-Trac, but the more I researched the more I realized that the trade-offs weren't worth it for me. Too much hp loss, fitment issues. I definitely didn't want an Eaton Posi, but I didn't want a Moser either because of all the pre-assembly required (and a couple other issues), so the True-Trac went out the window too.
I received the Strange a couple days ago and it is truly a beautiful piece of equipment to look at, talk about amazing welds! It looks like I did as good as I possibly could all things considered. You'll eventually finish sifting through all the options and settle on the setup with the compromises you think you can live with. Hang in there!
i got a 9" moser 31 spline axles w/ a locker....locker locker locker....hmmm wish i had a soft locker it drives fine until you make those things called turns then i go ahhhhhhhhh as the clunking begins and makes all sorts of nasty sounds.....i heard about posis blowin cause of launchin hard but never saw 1 yet....i just wanted 1 that helped with the track and still had SOME drivability....soft locker is way better from what i hear...i have no experience with a 12 bolt though so dont just toss it out the window....sooo in the great words of dane cook....choose wisely!
The Moser 9 inch with 31 spline axles, nodular center section (it's only 15 pounds heavier than the aluminum center) and the Truetrak is a great way to go. We install quite a few of these at my shop, and I have not run into fitment problems. I like the fact that the Moser 9 inch retains the factory two bolt mounting for the torque arm. With the Moser 12 bolt and the Moser 9 inch, the factory driveshaft length is retained, as well as any torque arm you wish to use will work. I have heard of several people saying their factory driveshaft worked, but they felt it was .5" too short, but I haven't ever noticed any problems. I suppose production tolerances could account for any discrepencies. Bob
Originally Posted by blue01ta
I find it kinda funny that so many people in this thread are voting for a rearend that they have never used or even seen in action. It does sound like a nice piece of equipment, but at the time so did the Edsel.
Good point, but its been a proven rearend for a LONG time, but not i a newer f-body I guess.
I'm not trying to say anything bad about the D60. I have a couple trucks that employed them and never had an issue with either what so ever. But I also owned and seen some pretty healthy Mustangs running an 8.8, some in the single digits without a problem. But that rear doesn't work too well in our cars. I understand that the previous statement is not exactly the same but it does prove my point.
