Rear End Additive
Old 04-02-2006, 11:03 PM
273sunsetZ's Avatar
Default Rear End Additive
I plan on changing rear end fluid pretty soon, do I have to mix an additive with the oil? My dad say's I do, and I can only get it from the dealer.
Old 04-02-2006, 11:37 PM
99huggerorangeZ's Avatar
only if you have the auburn posi, if you have the zexel torsion unit then you do not
Old 04-03-2006, 12:37 AM
Racer8102's Avatar
I always used Mobil-1 gear oil, and added a tube of limited slip addative with it. Never bought anything from the dealership.
Old 04-03-2006, 05:39 AM
tici's Avatar
On the Torsen homepage they say GM requires the additive because some units have a little noise
Old 04-03-2006, 05:52 AM
Predator's Avatar
That's strange, I always thought the additive was for the clutches in Eaton and Auburn limited slips.
Old 04-03-2006, 06:27 AM
8a8mfh's Avatar
The Eaton is a little forgiving and IIRC the newer ones (as in the past 8 years)with the carbon fiber clutches don't need the additive. But the Auburn needs only dealer additive, the parts store stuff in a tube does not work.
tici's Avatar
http://www.torsen.com/general/general_faq.htm
Is it true that the Torsen unit in the production Camaro needs the GM modifier added?
GM issued a technical bulletin adding modifier to the rear axle oil. This was done to quiet what we call a "Rusty Screw" noise that we heard in a very small percentage of vehicles. This does not happen in all cases, however to address owner's concerns we asked that the modifier be used in all instances to insure that the driver would not get this noise. When replacing the fluid it is at the owner's discretion whether or not to add the modifier. Elimination of the modifier does not affect durability of the differential.
Old 04-03-2006, 11:25 AM
OctaneZ28's Avatar
Some synthetic oils have the additive already in.
Like Royal Purple and Red Line... they already have the additive.
Old 04-03-2006, 02:22 PM
thats what i always thought
Old 04-03-2006, 11:34 PM
02WS6Bird's Avatar
Mobil 1 also supposedldly has the additive in it
Old 04-04-2006, 04:16 AM
tici's Avatar
We don't have all your brands over here
The only rear end oil with additive I can find is what is used in BMW's and costs about $60 a gallon...
Old 04-04-2006, 04:07 PM
OctaneZ28's Avatar
I've heard so too....
can someone here confrim or deny this???
Old 04-05-2006, 02:05 PM
dailydriver's Avatar
You do have Silkolene (Fuchs), don't you?? Although I'm not sure what a gallon of that goes for over in the land of chocolate and perfect watches.
Old 04-05-2006, 03:11 PM
tici's Avatar
Sikolene? What's that?
US cars parts cost here 2-3 times more than in the States.
Perfect watches... for example?
Old 10-08-2006, 10:23 AM
02gixxersix's Avatar
How do I know if I have the Auburn and/or need an additive. There seems to be a lot of conflicting info on here.
Old 10-08-2006, 11:21 AM
taintedmeat's Avatar
If it's an 02 you have a Torsen.
Old 10-08-2006, 02:17 PM
Mine is a 98 M6.
Old 10-11-2006, 03:37 PM
Mine is a 98 M6.
It's an Auburn, as long as you know no one has ever changed it.
Old 10-27-2006, 01:57 PM
richnew's Avatar
I have a 2002 Z28 some guy used 80-140 weght I thought the stock was 75-90 can I use the higher weght????? and skip the additive ????
