Redline shockproof: which viscosity for stock 10 bolt??
Old 04-30-2006, 09:12 AM
JR HAWK 9's Avatar
Default Redline shockproof: which viscosity for stock 10 bolt??
I am going to be changing my gear lube and want to run Redline's shockproof. I just don't know what run to run? They have superlight, lightweight and heavy. I am thinking heavy would do the trick. I don't drag race the car but I want something that will be good for the rear end.
thanks,
Paul
Old 05-01-2006, 09:44 AM
JR HAWK 9's Avatar
bump......
is Shockproof even a good choice for a stock 10 bolt with a Torsen??
Old 05-01-2006, 11:15 AM
horsekilla 95TA's Avatar
I have been wondering about this one myself...
Old 05-01-2006, 11:20 AM
JR HAWK 9's Avatar
yeah, I am thinking it may be too thick. I guess Speed, Inc recommends and uses Royal Purple 85/140 in the installs they do. I may just run that......
Old 05-01-2006, 01:41 PM
chicane's Avatar
If it were me I wouldnt use any of the previously mentioned products. But if I did, I would use the heaviest weight available.
IMHO the RedLine differential gear oil's are way too thin..... whether or not they say 90-140 or not. It doesnt have the 'film pressure strength' that is pretty manditory for a street driven chassis. My first experience with this was back in the late 80's during the "Corvette Challenge Series". RedLine was a sponsor and we tried their entire line to include their gear oils... but found we had to change the "Shock Proof" differential oil in it every race. Not to mention its running temperature was above acceptable limits. If you were to use it in a track car... Id say go for it. But yours isnt... so I wont.
The best lubericants I have found in the past 15+ years or so are:
Schaffer suspended moly, straight 90wt. (Passenger cars, front ends in 4x4, light duty, cold climate).
Schaffer ISO9000 suspended moly, straight 140wt (Passenger cars and trucks, street performance, rear in 4x4, heavy duty, all climate).
Schaffer ISO9000 suspended moly, straight 250wt (Trophy trucks,Top Fuel, Funny Car, Pro Stock and maximum effort high HP applications, trucks up to 5ton).
TORCO SGO/RGO 85-140wt (If you really thought a multi viscosity really means something in a diff. BTW, it doesnt).
LE 704-9920 75-140wt (same as above).
Amsoil SG 75-140 (same as above).
Royal Purple 85-140wt (same as above).
The parrifin based oils are the ticket.
Old 05-01-2006, 01:52 PM
GM Muscle's Avatar
I use the Heavy. It seems to work real well with the stock Torsen. I've also had great luck using the Amsoil SG (75-90) in my Silverado. It doesn't see track time but I beat the **** out of it on the trails and daily drive it.
Old 05-01-2006, 02:23 PM
INMY01TA's Avatar
When I put Redline gear oil in my 10 bolt/Torsen it started doing one wheel burnouts at the track. I use any non-syn. 80/90 dino gear oil in my 12 bolt. As recomended.
Old 05-06-2006, 09:34 PM
super_fro_daddy's Avatar
Originally Posted by chicane
Schaffer
Where can I find this. I googled it and everyplace I went only had the 90wt. Looking at the sponsor's sites I am not finding it. Can you PM me where I can get some?? Thanks.
What does that mean?? Again thanks.
Old 05-06-2006, 10:26 PM
Keysplayr's Avatar
Parrifin? As in the candle wax?
Old 05-07-2006, 08:59 PM
chicane's Avatar
Ahhh.... your a Uper. Your probably gonna have to call Gary in Manchester (PM sent). He's the only 'full line' dealer in MI. If he doesnt have it, he can get it to you. You are looking for the "#209A, red soluble-moly, 140wt". I dont know if he can get it in single quart quanities but Ill PM you another alternative supplier that can.
Well, candle wax is one of the many uses of Parrifin oil.
100% pure paraffin base oils are highly specialized non-corrosive thermally stable and thermally durable multi-functional extreme pressure applications, like that of highpoid gear set's..... meaning differential gearing.
Old 05-08-2006, 07:46 PM
billyb's Avatar
Default gear oil
always go with the manufactures recomendation they do all the testing to keep out the guess work, ck out auburn site ep 90 hypoid gear oil, 3 oz additive with every qt of gear oil ...
Old 05-13-2006, 04:58 PM
chicane's Avatar
Well, that is pretty easy for Auburn to say.... considering that their differentials are throw away units when the forcing cones wear.
Quick Reply: Redline shockproof: which viscosity for stock 10 bolt??
