12-bolt w/ stock supporting suspension
Old 05-02-2006, 04:44 PM
VaNDaL*SS*'s Avatar
Default 12-bolt w/ stock supporting suspension
i just put in my 12 bolt (M6 car) and right now i am running the stock supporting suspension (PHB, LCA, TA, sway bars, etc) will this be a problem with the new rear? i definitly plan on getting all that stuff, but the rear cleaned my clock moneywise. will i break things? thanks
Old 05-02-2006, 10:12 PM
Orange99Z's Avatar
You should have no problems.
Old 05-03-2006, 01:54 AM
VaNDaL*SS*'s Avatar
sweet thank you very much...
-ryan
Old 05-03-2006, 05:36 AM
EPP
EPP's Avatar
The rear should not strain things anymore than the stock rear. Keep an eye on the stock torque arm though, I have seen them break about 6 inches ahead of the rear. Bob
Old 05-05-2006, 08:52 AM
01bird58's Avatar
We busted our LCA's with the 10 bolt in. I wud imagine a sturdier 12 bolt would cause the LCA's to go even faster. (Given you beat the car as hard as we did)
Old 05-05-2006, 11:08 AM
VaNDaL*SS*'s Avatar
thanks for the info guys....i dont plan to have this stuff in here for too long. I would like to run at the track and see how times, 60's, etc change while i put this stuff in. U think some MT ET streets would destroy the TA or LCAs or anything else at the track?
Old 05-05-2006, 12:58 PM
BGImportkiller's Avatar
I wouldn't run with the stock TA too long. The angle is wrong because the 12 bolt is a bigger housing. Definitely dont launch hard with it cause you will break it. When I got my 12 bolt, before my TA i bent the stock 1 with just drivin on the street.
Old 05-05-2006, 01:29 PM
INMY01TA's Avatar
Stock suspension here with Strange 12 bolt for bout 3 years, no problems yet.
