What broke in your 12 bolt and whos was it??
It seems that most people are saying with a M6 that you have to go 9" and I just cant see that being the case. It seems most of the problems stem from production line building. Just trying to get some insight here.
From what i've seen at local tracks and from here the weakpoint of the 12 bolts seem to be the Eaton Posi's. Then seem to not like H/C power and high rpm slick dumps. I've not heard of too many spooled 12 bolts having problems doing the above. Hopefully the new Detroit TruTrak is proving to be stronger than the Eaton and should alleviate some 12 bolt problems.
thats what I thought.
Originally Posted by SSmokin 01
Strange 12 bolt w/3.73's & 33 spline axles.
Spider gears and side gears went in the posi.
Launching @ 4K, 3750 lbs on a 325/50 MT DR.
614 rwhp / 537 rwtq
Replaced with a trutrac. I'll be at a track rental in a couple weeks to test it out.
614 rwhp / 537 rwtq
how long did that take?
The first 30 passes were on 17" DR's with soft 60'. The last 4 were on 325/50/15 DR's. As soon as it hooked on the last pass it was dead. The ring and pinion were fine. Just the spider and side gears. I blame the posi, not the rear.
Looks like what you needed was a heat treated 10-17 spider gear kit. The teeth of the pictured gears, failed due to impact loading.... eg. drag racing.
The Eatons available are almost near what Eaton put out stock, some 38+ years ago..... but the difference was the heat treat of the 10-17 gears and solid clutches.
Out of the several hundred 12 bolts I have built, I have seen that the older parts are much better. But what you as the end consumer know (or are being told) is that you can just drop this into your ride and it will live. Even some 38+ years ago, when dealing with roughly the same power levels, the failures that I keep hearing about are from the newer re-pop Eatons.
I wouldnt have sold you a stock Eaton if I knew that you were going to be putting that much power to the ground and what your actual use was. Sounds like a salesman with his proverbial head up his ***.
so it seems most of the breakage has come from "packaged" rear ends, the ones built by local shops seem to not have troubles. Except for the posi units, which I think the "HD" units which usually means it has stiffer preload springs in it, would be worse on a DD because the clutches have to slip when turning. That would lead to more wear. The true trac should really help and I think non production line assembly is the key.
614 rwhp / 537 rwtq
614 rwhp / 537 rwtq
Kleeborp the Moderator™
SSmokin...was the True Trac a straight drop-in? I was told that it might not be due to the Strange axles being a little different than the Moser axles that are usually used with these in their 12-bolts. I'll give the Eaton that came in my Strange a shot though...I don't do any heavy drag racing at all, so I'm sure it'll live...it's a matter of whether or not I like it for daily driving.
Originally Posted by zlover129
^^^you reqouted all those pics just to ask for a part number? Just delete the img tags man and save us all some screen space
Now shoot us the part #
Model # from the box. It's also stamped on the diff in the pic.
914A576 TT GM 8 7/8 33T
It dropped right in for me. I put new carrier bearings on, swapped my 3.73 ring gear, and used the same shims. Backlash was within spec as well as wear pattern. I don't have any ABS now though. This is a 3 channel rear (No ASR).If you want that you'll need to have the case machined and have a reluctor ring welded on. You can see the ring on the broken diff in the pic.
4 channel with the rings on each axle may not have this issue.
I bought mine local. This is what comes up at Summit if you punch it in.
DTL-914A576 $439.95
Estimated Ship Date: 1/26/07
Brand: Detroit Locker
Product Line: Eaton Detroit Lockers
Aftermarket Carrier Style: Detroit locker
Cover Bolts: 12
Carrier Series: 3
Axle Shaft Spline Quantity: 33
Manufacturer of Axle: GM
Carrier Material: Steel
Quantity: Sold individually.
Notes: Fits 3.08 - 3.90 gear ratio only.
Cover Bolts: 12
Carrier Series: 3
Thanks! I need a 4series though. I'm looking on summit but no luck
EDIT
found it
http://www.detroitlocker.com/images/LTPCAGweb91305.pdf
DTL-914A575 $419.95
Estimated Ship Date: Today
Cover Bolts: 12
Carrier Series: 4
Notes: Fits 4.10 and numerically higher gear ratios only.
A little cheaper too
EDIT
found it
DTL-914A575 $419.95
Cover Bolts: 12
Carrier Series: 4
I thrashed a Moser 12 bolt w h/cam & nitrous. Left at 4000 rpm on slicks , no bottle and broke the ring and pinion ( which was a richmond ). I think it broke due to Moser setting it up wrong or to lose, but whatever.
