Will a 10bolt hold with my mods and ET Streets??
Old 07-06-2006, 05:00 PM
RGV_Z28's Avatar
Default Will a 10bolt hold with my mods and ET Streets??
I just got my MS4, 4400 stall, and 3.73's. I'm gonna purchase a T/A rear end cover. Getting a pretty good deal on some ET Streets. Will the real hold, or should I just buy some Drag Radials?? Thanks.
Old 07-06-2006, 05:23 PM
TheCarKid's Avatar
I wouldn't count on it holding up for long
Old 07-06-2006, 05:43 PM
jmill96Z's Avatar
Neither are gonna be good for it. It'll probably hold for a while being that you have an A4. I've seen guys with similar setups run a few years on the 10 bolt with the old 4L. I would go for the ET's and if it breaks just upgrade
Old 07-06-2006, 06:35 PM
SuperSam's Avatar
It will hold. If you are planning on staying with the 10 bolt, you might want to look into getting some moser axels or something around those lines, any bit helps.
Old 07-07-2006, 09:40 AM
RGV_Z28's Avatar
Thanks guys.
Old 07-07-2006, 05:01 PM
SVT THIS's Avatar
How many miles does it have on it? I think you should say screw the TA cover and moser axles and start setting money aside for a 12 bolt. Some peoples 10 bolts hold up to turbo and N20 passes, my first 10 bolt broke with a stock motor. I would plan on it breaking and be happy if it doesn't.
Old 07-07-2006, 05:07 PM
keliente's Avatar
https://ls1tech.com/forums/gears-axles/510589-when-will-my-10-bolt-break.html
