Strongest Wheel Studs for stock O.E wheels
strongest , largest wheel studs that will fit in a set of 17x9 Ws6 wheels , soon to be 17x11's
this will be for the rear , can I bore the rim wholes out for 5/8'' studs
Moser 9'' coming soon so I need help .
Im going to run spacers when I widen my rears and with a new rear end all built up it seems stupid to run factory studs . I posted this in the wheel/tire section but didnt get any help .
I want to be able to daily drive this car with the street wheels then swap over to the drag wheel setup . What studs would you recommend.
What studs for 5500rpm dumps on MT Et streets .
Using the ARP 100-7708 with the draglites (similar to prostars) and stock wheels, these are 2.5" studs. ARP also has 100-7713 that are 3.25". Both of these have same knurl and thread pitch with stock.
Thanks!
I used the weld 601-1412 closed end 1.380" shank length, 0.687" shank dia. The open end equevalent is 601-1422. McGard, Gorilla and Crager have similar lugnuts.
Originally Posted by GTA91
Closed end? Really? I figured these studs were too long to run regular closed end lug nuts. Hmmmmmm
