Thunder Racing Complete Gear Package for GM 7.5" 10 Bolt
Old 04-06-2007, 10:59 AM
sbusby's Avatar
Default Thunder Racing Complete Gear Package for GM 7.5" 10 Bolt
I'm looking to purchase the Complete Gear Package for GM 7.5" 10 Bolt from Thunder Racing and wondering if the upgrade is worth it. I would be going with the 3.73 gear ratio and the kit seems it will add some strength to the rear end, though it's not a 9" or 12 bolt.. I just don't have the money for that.
The package comes with;
MOTIVE Gears, in your choice of ratio...3.42, 3.73, 3.90 or 4.10
Or, STRANGE Gears (2 or 3 series carrier) for $35 additional
RATECH Complete Gear Installation Kit
2 Quarts RED LINE or ROYAL PURPLE Synthetic Gear Oil
1 Bottle GM Limited Slip Differential Additive
TA Performance Rear End Cover Girdle Engraved w/Thunder Racing Logo
TA Performance Stud Kit
Sorry if this is a repost - I tried searching but only gives me a blank page.
Old 04-06-2007, 12:20 PM
Viper's Avatar
I think it's worth it. I would throw in a solid pinion racer, only an extra $25 i believe.
Old 04-06-2007, 12:26 PM
sbusby's Avatar
Are the strange gears worth it? Not alot extra, just curious if they're just a name or actual quality?
Old 04-06-2007, 12:42 PM
Viper's Avatar
If you took a poll you would probably hear 50/50 Strange vs. Motive.
Old 04-06-2007, 12:53 PM
EvilCamaroSS's Avatar
how much?
Old 04-06-2007, 12:54 PM
sbusby's Avatar
Old 04-06-2007, 02:36 PM
Wezie F Baby's Avatar
From what I hear Strange makes less noise.
I'm getting that same kit w/ 4.10's installed on a spare rear now. Kit looks pretty good to me, I say go for it.
Old 04-06-2007, 02:37 PM
sbusby's Avatar
Thank you for all of your input!!!!
Old 04-06-2007, 03:02 PM
Redlinez's Avatar
I have had problems with Ratech parts. I recommend Genuine GM bearings period. JMHO. GM crush sleeve, pinion bearing, pinion nut, etc.
Old 04-06-2007, 03:36 PM
14 Second Truck Club
mzoomora's Avatar
GM and Ratech do not make bearings. If you have a choice I would reccomend Timken bearings. All the major brands are good, Korean bearings are usually junk, with chinese right behind. US, japanese are both pretty good.
Old 04-06-2007, 03:42 PM
ibanez7's Avatar
timken defefinitely!!!
also for the install randysgears.com has good info
Old 04-06-2007, 04:13 PM
Yall would chime in with this info after I've spent the money on everthing LOL
Old 04-06-2007, 04:22 PM
gillbot's Avatar
I like timken bearings but then again I work there!
Old 04-07-2007, 12:37 AM
eagleknight97's Avatar
Where can you get Timken bearings at?
Old 04-07-2007, 02:58 AM
LS1>girlfriend's Avatar
almost any parts store - NAPA, autozone, advanced etc
might consider trying the mikronite process.
Old 04-07-2007, 12:38 PM
ls1pwrdss's Avatar
timkin makes gm's bearings
yes the kit is worth it
the solid pinnion spacer is a pain in the *** to get set rite
it involves taking the rear end apart several time to get rite
because basicly you cant go off of the used crush sleve
you have to assembly the rear end pinnion depth has to be rite and back lash has to be rite with new crush sleve used with the proper turning torque of the pinnion as well then take it all apart mesure the new crush sleve that has been crushed and shim the solid spacer to the same measure ment.
it works well when set up rite just takes for ever
Old 04-07-2007, 12:39 PM
Viper's Avatar
I agree it takes forever but worth it.
Old 04-07-2007, 01:10 PM
So what bearings are included in the Thunder kit? Its a Ratech kit, but what bearings are included in that?
Old 04-07-2007, 03:57 PM
ls1pwrdss's Avatar
the bearings in the thunder kit are top notch when i do installs on rear ends thunder is my supplier i have never had a rear end fail yet. ive only had 1 guy brake about 6 teeth off of a ring gear with a six speed car only becazuse he launched it at about 5 grand with 28 in slicks
Old 04-08-2007, 12:46 AM
MannyZ28's Avatar
And this was with the stock 10 bolt?
Quick Reply: Thunder Racing Complete Gear Package for GM 7.5" 10 Bolt
