Had a strange situation at the track tonight. looking for advice/suggestions.
Old 04-07-2007, 02:34 AM
usd2sing's Avatar
Default Had a strange situation at the track tonight. looking for advice/suggestions.
breakdown:
a4, 10 bolt, stock 3.42's, mini spool.
making 1st pass, did the burnout. pulled up to the line, brake stalled up.
launched and heard a POP, shut it down.
rear end was locked up or at least we couldnt get it to roll off the track.
track guys put it on dollies and towed me off the track.
tow truck shows up.
we pull the dollies out and the rear wasnt locked up anymore.
car rolled fine, no noise were present.
got the car home and jacked it up, started it, put it in gear and its seems fine. tried all gears, 1,2,3,od and R.
both wheels spinning together, no noise.
did notice a new a decent 'gouge/grind" mark on the dr side disc that wasnt present prior to the event.
lookin for some suggestions on what direction to go to find out what happened?
havent driven the car yet. (its late, im stressed)
last night the car pulled several 1.5x shorts without issue.
thanks in advance gang.
PS. yes, we all know the stock rear is weak, im more interested in finding out what happened. anybody else have anything like this happen????????
Old 04-07-2007, 02:44 AM
SpaZMaN's Avatar
did you pull the rear cover off?
Old 04-07-2007, 02:47 AM
usd2sing's Avatar
not yet bro.
tomorrow morn i'll do that...im just researching, lookin for advice suggestions.
its almost 3am, been home for 45mn..sigh im bushed..hehe
Old 04-07-2007, 02:48 AM
chicane's Avatar
Cross shaft or CS retaining bolt...
Old 04-07-2007, 02:51 AM
LS1>girlfriend's Avatar
maybe had some weird brake malfunction? i would pull the pads and rotor to have a look
Old 04-07-2007, 01:27 PM
ski23's Avatar
pull the cover. probably had a chunk of broken ring gear wedged so it wouldnt spin with the pinion. dont know what it could be till ya pull the cover
Old 04-07-2007, 01:29 PM
SpaZMaN's Avatar
how deep is the grind on the disk? i'd still pull the cover off to make sure you did not lose a tooth or something
Old 04-07-2007, 02:12 PM
usd2sing's Avatar
update gang.
thanks for the responses.
just pulled the whls and calipers.
pass side axle solid.
drv side axle pulled right out after removing the caliper.
gonna pull the cover after i grub some food.
BTW, V6 camaro..
Old 04-07-2007, 02:16 PM
i love carnage .
