moser/ TA help
moser/ TA help
Installed my 12 bolt and used the stock TA. Well I go to launch the car at the track and it breaks the drive shaft (aluminum) and rips the bolts out of the torque arm. Now I've read of these doing this but can't seem to find any help or threads on it. Anyone has an idea how to fix this or re-inforce it? thanks.
Thanks! It's ripping the bolt hole out of the back of the tq arm. Just wondering if there was any re-inforcing I could do. It's not backing out or anything just flat out ripping it off.
Get a UMI torque arm and you wont have to worry about it the stock ones or junk just like the stock rear ends.
Originally Posted by BadCompany VP WS6
Pretty hard. This is the 2nd tq arm in two days it has done this. Many of my other friends who are going way faster have no problems.
dont go bmr cause i broke that tq arm relocation mount more than once. If the bolts broke in the rear youll have to drop the rear end and back those bolts out, re-thread and then use the red loctite when installing those bolts. You can aslo go as far as welding the bracket from the tq arm to the moser.
