Leak in rear differential??
So I just got an oil change and the guy says there's a leak in my rear differential... He says he doesn't know what it could be, any of you have any advice? Its a 98 z28 convertible with 78k on the clock.
A leak at the pinion seal is very common in the F-body so my guess would be that. It's a PITA to do. But if it's only the gasket, it's an easy fix. Go to installuniversity for instructions.
Originally Posted by Fibbado
If he said that he doesn't know what it could be don't take it back to him to fix it
It is not hard to do, if you do decide to do it yourself, on thing that i found with changing my rear dif. fluid and my trannie fluid is...make sure you have a oil siphon pump. You can buy it at almos any auto parts store and it makes life a lot easier! instead of trying to get a bottle or funnel into the fill plug, just use the pump. It made my job a LOT easier. Another note if you do it youself, change your trannie fluid while your down there...i used Royal Purple and noticed a hell of a diffrence. My Firebird is much more quiet and i got a 10 hp gain just by changeing the trannie fluid and the rear diff. Hope this helps
