bout to get a 9 inch
thinking about it...hear alot of bad from the 12 bolt...hear about more options for the 9 inch as far as gears go...but every1 i talk to around here that deals with rear ends are telling me its rediculous to get a 9 inch for 2500 bux...they tell me this shop or that shop will do it for 1500 or 1200?
anyways where do you guys recommend getting a 9 inch from? or do yall think a 12 bolt is better?
what options are available and what do yall reccomend...
i am planning on going stock style suspension...and im going to want a custom d/s with it to hold say 1000 hp and mate to my 4l60-e
so yall guys tell me what i need to do
o yeah...and i wanna be able to run my damn salad shooters, so i dont think i can go more than 1 inch narrower? if that
what is the advantage of narrowing it?
If you want to do this on the cheap it can be done for about $1500. You can get the housing and the axles from Moser for about $1k and then pick up a center section from ebay or wherever for $500ish. A friend of mine did thisin his 10sec Camaro and never had any issues drag racing for a year.
Originally Posted by daniel6718
if i had the welder ect i might try it, but i want something i can buy bolt on parts for later...
also i see moser has a 9 inch and 12 bolt...but the 9 inch has no abs only option, i must keep this!
so strange has a 12 bolt, id like to get a 9 inch though, do they have one?
do i have any opther options besides the big heavy s60? id rather not go that far...i made the 10 bolt go 1.50...dont hink i need a s60
so yall are telling me a typical 9 inch will bolt into a f-body? from what car? the lca will bolt up? shocks? spring perches? panhard rod? and tq arm? i didnt think so...
^yea what Bob said... Like I said in my original post, it's $1k for the Moser "bolt in" housing and axles.
As fas as ABS goes, well you "can" make 3 chan ABS work with a 9" but you'll have to fab up a bracket for the sensor and source a correctly toothed wheel to mount on the drive shaft yoke.
Or you can pony up and lay down the $$$ for a 3 chan 12 bolt, or find a deal on a used in the for sale section like I did. Even if you find a deal on a used 4 chan 12 bolt, it'll cost about $150 to have it coverted to 3 chan.
Moser and Strange offer 12 bolts with ABS, or with ABS and TCS. The nine inch rears can only be had with ABS/TCS, ABS only is not an option. There is a thread on here on how to make ABS only work on the nine inch rears.
I sell a lot of nine inch rears to people who do have ABS, and they just order the rear and disconnect the ABS. Personally, I don't like ABS, I prefer controlling the brakes myself. Bob
Not to mention if you can't have ABS with a 9, you could remove the ABS pump and components if you're technically proficient right?
So I could piece together a 9" and assemble it myself for considerably less than the average $2300-2500? I didn't see the housing and axles on your site separately.
well then i think il go with a strange 12 bolt...i want my abs, ive had those panic situations and lose controal because os no abs...ill pay the ectra money since im stil ldriving it on the street
can i buy just a housing axles gears reluctior ring and carrier, have some1 local put it together? what would that cost?
or do yall reccomend an s60?
Here is our Moser housing/axle package. You didn't miss seeing it before, I just added it to my website! Thanks for inquiring. Bob
