gear whine????
Old 11-15-2007, 06:48 PM
coreygalyk13's Avatar
Default gear whine????
ok i have a 97 z with an auto trans and richmond 3.73's in the rear with and auburn posi....well the gears whine around 40mph which drives me insane because of the fact thats the speed i drive everytime im in town...well anyway i asked the guy if he could fix it and he said he can't....he said the richmonds are almost impossible to stop from whining....is this true? do you guess think i could take it somewhere else and get rid of that whine?
Old 11-15-2007, 10:13 PM
chicane's Avatar
Is it impossible to have quiet Richmonds ?? ... No, its not impossible.
Can you fix the whine ?? ... Not really. You could re-set them, but that is going to be hit or miss too. Once they have been heat cycled and have had a few miles on them, its near impossible after they have been work hardend. You could start by changing out to a straight weight 140 gear lube... but... there is no much else you can do.
If you found the right guy... he might be able to quiet them down, but I doubt they will become silent. The biggest problem is finding that one guy that knows and understands the black art of setting up a quiet set of gears. One hint... he'll be the guy that will split hairs over a 0.0005 to 0.001" pinion depth change before he is satified.
Old 11-15-2007, 10:19 PM
lol so i have no hope i see.....not many people around here know how to do gears
Old 11-16-2007, 12:10 AM
chicane's Avatar
I dont know about that... where are you (generally speaking) ??
Old 11-17-2007, 09:09 AM
marion, ohio
Old 11-17-2007, 11:59 AM
ndfrsd6's Avatar
yeah gear whine will be there with richmond gears ....i have 4.56 in mine and got it to quiet down a little with some thicker lube ...but it will on average be there with bigger gears.
Old 11-17-2007, 12:05 PM
Retired Street Racer
Matt D's Avatar
Richmonds are known to whine. Just open up the exhaust a little more or turn up the radio. That is the only way to quiet the down.
Old 11-17-2007, 12:39 PM
my exhaust isnt getting any louder due to the fact i already have bbk headers into an slp lm2 with no cats and a cam...lol
Old 11-17-2007, 09:57 PM
Matt D's Avatar
I have Richmonds in mine and they whine, but I have dumped oval mufflers off of the header collectors, so it drowns it out pretty good. As long as they aren't clunking or grinding, you'll be okay.
Old 11-25-2007, 08:54 PM
but basically if i use 140w gear oil that may tame them down....how many bottles will i need
Old 11-25-2007, 11:15 PM
chicane's Avatar
2.5 qts is required... so 3 would do the trick.
Old 11-27-2007, 09:50 AM
but this isnt a bad thing is it....its loudest at 40mph but has iit at other speeds just not very loud at all....this isnt going to mess up my tranny is it?
Old 11-27-2007, 10:06 PM
anyone? and 140w will do the trick if its just the gears right?
Old 11-27-2007, 11:33 PM
chicane's Avatar
No it wont harm the transmission.
And... 140wt can help... but I wouldnt expect it to completely solve the issue. It will help though.
