if 10 bolt breaks will i need to replace just gears or everything?
Old 12-05-2007, 06:59 PM
motownZ's Avatar
Default if 10 bolt breaks will i need to replace just gears or everything?
just wondering if my rear end breaks is it just the gears that will need to be replaced or the whole unit
Old 12-05-2007, 07:07 PM
SpaZMaN's Avatar
It really depends on what broke, when i ripped about the drivers bearing i just bought a used rearend from a local shop for 150, included everything(both axles, gear, posi unit, case ect.)
Old 12-05-2007, 07:15 PM
xtreme2001's Avatar
like the above post stated it depends on what breaks.when i broke mine i broke the spider gears in my auburn carrier.i just replaced carriers.
Old 12-05-2007, 07:32 PM
Jawsgear's Avatar
Depneds on what breaks as far as what you should replace when doing the repair.
Jeff
Old 12-05-2007, 10:48 PM
BriancWS6's Avatar
Some people break an axle, some strip the pinion gear, some toast the posi. Personally, I shredded the gears in my Torsen on the 1-2 shift.
Old 12-06-2007, 12:36 AM
tripblackls1's Avatar
well myself i have roasted two posi units first one kill the gears in torsen and second completly destroyed a eaton(came out in two parts, i have pics in when will my 10 bolt break)
Old 12-06-2007, 01:37 AM
99mongooSS's Avatar
has anybody used an aftermarket posi, with moser axles with c-clip elim., and stronger gears? And if so Im interested in what kind of times they ran, or if not at the track how much power are you able to put through it? I know that the 10 bolt is still weak but im interested to know seeing as you can build up one of those up for about a third of the price for a 9'' or 12 bolt.
Old 12-06-2007, 01:16 PM
BriancWS6's Avatar
The problem with the 10 bolt is that even if you put in better quality parts, they're still too small to take the beating. Save yourself time, money, and headache, and set the money back to go towards a 9in if your an m6, or 12 bolt if your an a4.
Old 12-06-2007, 11:22 PM
02Z28LS1's Avatar
Originally Posted by BriancWS6
.....set the money back to go towards a 9in if your an m6, or 12 bolt if your an a4.
well, that all depends on the application, too
for semi-serious drag racing, then yeah. but if you're into auto-x/road race, or just want a semi-bulletproof street car rear, my money would go on a Strange 12-bolt. it's lighter and will sap less power than a 9" will.
Old 12-06-2007, 11:52 PM
Hennytime's Avatar
just replace it with another whole unit, they are like 200 bucks
