Rear-end weights - Post what you have
Stock 10 bolt with stock brakes and stock calipers = 198lbs, believe it or not. We just weighed one!
M9 with LCA relocation brackets , BMR Xtreme Sway brackets welded on
Full Red Powdercoat
Fill + Drain plug
Full Spool
Billet pinion yoke
Aluminum Center Section
Moser Extreme 40 spline gun drilled axles star flanged
5/8's wheel studs
Moser M9 above, assembled with Wilwood brakes/calipers minus the torque arm and tranny crossmember = 198 lbs
Keep in mind the Wilwood brakes are indeed lighter. Bob
From JeffT
Moser 9 INCH original style housing at stock width with Spohn LCA relocation brackets
Black spay paint
Fill and drain plug
Steel spool
Billet pinion yoke
Moser nodular iron center section
Moser 35 spline gun drilled & star flanged axles
5/8"x2" drive studs
Assembled with Strange rotors & calipers
Includes Moser T/A adaptor bracket
Includes Wolfe anti roll bar (15 pounds)
Fluid
239#'s
Moser 12 bolt for a third gen f-body that weighed in at 193#'s with 33 spline axles, Eaton limited slip, aluminum cover, no brakes or fluid.
waterbug1999
I swapped out my beefed up 10 bolt for a MWC 9" a few months back... This was the rear and backing plates on both.
The 9" was 10 lbs lighter. Only thing different between the two rears was the 10 bolt had oil and the 9" was dry. If Im not mistaken, the 10 bolt was ~163ish and the 9" was ~153ish.
I also bought the MWC TQ arm that comes with it, it was 20 lbs lighter then my Spohn TQ arm was.
MADMAN
Burkhart 100% chromemoly housing, Moser aluminum center section, 35 spline axles star flanged and gundrilled. Dual Strange caliper brakes, Moser torque arm mount with Madman torque arm came in at 184lbs. full of oil
3.50 35 spline Pro Gear with a steel spool. The caliper brackets are alot lighter than stock.
studderin
10bolt was 150lbs
s60 was 196 lbs
WAHUSKER
My M9 weighed 40 lbs less than my Moser 9" did. I think the #s were 195 vs. 235 fully dressed....looking.
Exotic Performance Plus
Moser M9 Housing with ends welded on and torque arm brackets welded on, minus control arm brackets. 48.5 lbs.
We had the housing above made for an '06 GTO, and we need to locate the lower control arms ourselves. This is why the above rear does not have lower control arm brackets already installed on it. Bob
bad6as
in my 9" strange s case 3.90s and truetrac was 76lbs went to a strange steel spool and saved 8lbs
dlove
Strange 12 bolt w/ strange brakes
Narrowed 3'' per side
spool, 4.11's
lightweight yoke
lightweight axle ends
Aluminum cover
The weight with fluid is...... 180lbs
My stock 10bolt with auburn limited slip and stock brakes:
205lbs
jetlag
I haven't installed the 9" yet, but I already removed the 10 bolt. It was ~157 full of fluid with no brakes.
Mikey 97Z M6
Quick Performance 9" Housing
Bare Housing with T/A Bracket = 75 lbs
Moser 31 spline Axles with Bearings = 18/19 = 37 lbs
Strange 'S' Case, Nodular Iron
Aluminum Daytona Pinion Support
Detroit Locker (Large Bearing, 3.25")
3.89 Gears
Billet Steel 1350 Yoke
Assembled Center Section Total = 71 lbs
Still to come:
LT1 Brake Backing Plates = ?
LT1 Sway Bar w/Brackets = ?
ss1
I pulled the rear end out of my car the other day and weighed it.
Strange 12-bolt, 4.11's, posi unit, complete brakes, 3qts fluid. - 228lbs
BADD SS
OLd moser 12 bolt w/33 spline eaton posi
4.11 gears
alum cover
4 channel abs
backing plates and caliper mount
215 lbs minus the spider gears, because they flowed out with the oil, in 2000 little pieces...
NEW
Strange 9" Housing, 3.250" .250 Wall axle tubes, internal gussets and back braced. Narrowed 4" per side for 8" total
My own custom 4130 lca, coil over, PHR and torque arm brackets.
Moser alum case
35 spline strange axles
steel pinion support
4.57 gears
steel spool
aluminum caliper mounts
154lbs.
FirstYrLS1Z
GM 10 bolt 4 channel out of a 2001 SS fluid drained;
-complete with rotors,backing plates+dust shields-178 lbs.
-less rotors,backing plates+dust shields-140 lbs.
-less axles,but with carrier+gears-105 lbs.
studderin
I saved 32.8#s going to a strange steel spool, from a truetrack in my s60.
The the dyno showed 14more hp, same mods
EPP my other weights for the rear ends, were with no brakes but both had stock backing plates. (sent a extra set to strange to install)
Full Red Powdercoat
Fill + Drain plug
Full Spool
Billet pinion yoke
5/8's wheel studs
From JeffT
Black spay paint
Fill and drain plug
Steel spool
Billet pinion yoke
5/8"x2" drive studs
Fluid
239#'s
waterbug1999
MADMAN
studderin
10bolt was 150lbs
s60 was 196 lbs
WAHUSKER
bad6as
dlove
spool, 4.11's
lightweight yoke
Aluminum cover
205lbs
jetlag
Mikey 97Z M6
3.89 Gears
Still to come:
ss1
BADD SS
4.11 gears
alum cover
4 channel abs
NEW
Moser alum case
4.57 gears
steel spool
154lbs.
FirstYrLS1Z
studderin
We just installed a Moser nine inch with a Truetrac and 31 spline axles, but it didn't get weighed. We have another Moser 9 inch on it's way for a customer's car with a brand new option that Moser hasn't yet had. We'll weigh this one for sure. Bob
We weighed a stock 10 bolt with no brakes on it vs a 9inch with Detroit Locker, 35 Spline Axles and the trq arm mount also with no brakes and it was a good bit heavier. If i remember correctly it was a good bit over 50lbs heavier, this also didn't have the aluminum center section.
Moser original style housing at stock width with Spohn LCA relocation brackets
Black spay paint
Fill and drain plug
Steel spool
Billet pinion yoke
5/8"x2" drive studs
Fluid
239#'s
Take off 15#'s for an aluminum center and another 15#'s for the Wolfe bar and you're at 209#'s. That gets you about 11#'s for the housing difference.
Forgot to add, I've got a Moser 12 bolt for a third gen f-body that weighed in at 193#'s with 33 spline axles, Eaton limited slip, aluminum cover, no brakes or fluid.
Black spay paint
Fill and drain plug
Steel spool
Billet pinion yoke
5/8"x2" drive studs
Fluid
239#'s
Good to see this thread. I want a light 9" housing with gundrilled axles, aluminum center , lightened ring gear and that trick aluminum diff with 3.90 geras. Currie has some track 9 stuff with .188 tubes but they don't put f-bod brakes on it. My 10 bolt is busted now. Who's gonna make me a rear the way I want???? Have cash in hand
Also what kind of differential?? like a spool or torsen? etc..
lastly the strange caliper brakes, how light are those compared to OEM rotors and stock calipers?
because if all of this is what I wanna hear, this is a differential WORTH spending $$ on on
my s60 and my stock 10bolt
http://www.newyorkfbody.com/viewtopic.php?t=3928
10bolt was 150lbs
s60 was 196 lbs
more info I posted about both
https://ls1tech.com/forums/showthrea...&highlight=s60
10bolt was 150lbs
s60 was 196 lbs
