Quick Rear End Question!
can i bolt a 97 rear end to my car? i found a great deal on a 97 10 bolt with 373s and gotta act fast if it does work, i wanted to know if i can get it, and throw it on my car? my car is a 2000 ls1.
thanks in advance!
thanks in advance!
really? hmmm the wheels are 17x11 zr1s. with 315 drag radials.
theres no way to take the brake mounting stuff off my car, and put it on the other rear end?
Yes, you have to remove the flanges (backing plates) and swap everythign between the two. you could technically run the earlier brakes (guys that run 15" drag wheels do). THe only thing to check is to see if the two rear ends are both 3 channel or 4 channel abs. Do both cars have (or not have) Traction control?
Rear ends between 93-2002 are the same for V6 & V8 cars. Although some are limited slip and others are non not. 1982-1992 Camaro rear ends would also work in non TCS cars but those do have a slightly different width and the ring gear is a tad smaller.
thanks bro! thats alot of help! my car has traction control. i have to find out if the other one does or not. is it a PITA changing the backing plates? i mite just run the 15in lt1 breaks cuz i do plan on running pro stars....
LMAO..dont worry joe. its just for these two months. my rear is going out. im getting a 12 bolt with tax return, and hopefully a FAST.
one more question for you guys. how do if the rear end is a 4 channel or 3 channel? i want to make sure before i drive and go get it.. can somebody tell me the physical difference. so can ask the guy..
thanks!
thanks!
thanks!
thanks!
Im messing with yea!
just got off the phone with the guy. its a 3 channel. but he was explaning to me that i can just take off the backing plates, and all the stuff off my current rear end, and place it on that one. is this true? that way i can keep my abs. if not, and i did use this rear end.. i just wouldnt have abs in the back right?
yea...unless i swappped all from my rear end... its all good. since it came down to that i already have 342s. just the car is tuned to 273s i left my rear end. no point in the extra work. rear already sold and im picking up some 373s one friday. so hopefully once tuned to the right gear, and with the new 373s car makes a noticeable difference
