ford 9 inch
Old 01-29-2008, 07:49 AM
snkeater's Avatar
Default ford 9 inch
I recently got my hands on a ford 9 inch rear end and I wanted to convert it and put it in my 01 trans am. i really dont know much bout what all goes into it. can someone please shed some light in what i need. I plan to put some 3.73 gears. my car is an automatic without traction control
thanks
Old 01-29-2008, 08:09 AM
One Bad Z's Avatar
Is the rearend & suspension brackets setup or an f-body/what did the rearend come off of?
Old 01-29-2008, 08:44 AM
BIG_MIKE2005's Avatar
Dude your in for alot of work making one that isn't already adapted to a f-body fit. It's not even worth the hassle. Just keep the center section & buy a Moser Housing/Axle package & be done with it.
Old 01-29-2008, 08:45 AM
EPP
EPP's Avatar
If the rear is not designed for an f body, your best bet is to buy a Moser housing and axle package for $1050.00 shipped. http://www.exoticperformanceplus.com...html?item=1116 You would then use the center section from the 9 inch rear that you currently have. You won't have your ABS working, but that is not a problem for most people. If you do need to keep your ABS, Moser now offers complete 9 inch rears with the ABS option.
You can find them here. http://www.exoticperformanceplus.com....html?item=145
To use your housing and to try to modify it to make it work on an F Body, if it was not designed for our cars, is expensive and a real hassle. Bob
Old 01-29-2008, 09:30 AM
Jays00ss's Avatar
I agree listen to these guys
Old 01-29-2008, 10:14 AM
Jawsgear's Avatar
thanks
Don't waste your time. Too much trouble and work to modify one. Buy the housing and axle package and save yourself the headache. Units start at $975.00 for the F Body on our website. Check it out and let me know if you have any questions. Free shipping included.
Link:www.jawsgear.com/Fbody
Jeff
Old 01-29-2008, 05:57 PM
snkeater's Avatar
no. the rearend came off a van. thanks guys for the imput.
Old 01-30-2008, 04:38 AM
EPP
EPP's Avatar
Smile
Yes, you would be better off using the center section with the Moser housing/axle package. Bob
Quick Reply: ford 9 inch
