10 bolt groaning while turning
Old 02-07-2008, 04:08 PM
Wsteun's Avatar
Default 10 bolt groaning while turning
The rear end on my car makes a groaning/low pitched whine when turning left or right, going backwards or fowards at low speeds. It doesn't whine, or make any strange noises while the car is driving at highway speeds, or in the city. Suggestions?
Old 02-07-2008, 10:24 PM
Wsteun's Avatar
Anybody got an idea?
Old 02-08-2008, 03:24 AM
Benny Blanco's Avatar
hahahahaha damn mine is starting to do that too???? I just put a new gasket on my diff too???? But it runs perfect but makes weird noises from time to time i have a factory auburn diff I wonder if its that. I have TSP trues and barly hear anything anyways????? BB
Old 02-08-2008, 02:14 PM
Wsteun's Avatar
Mine only makes noise when I'm turning at low MPH. It doesn't do make any noise, unless I'm turning. I think I have the auburn diff as well.
Old 02-08-2008, 02:17 PM
9formula4's Avatar
maybe the axle bearings are going bad or even the carrier bearings. Could also be lack of fluid.
Check the ovious before getting to far into it.
Old 02-09-2008, 12:23 AM
Wsteun's Avatar
After I install my LS6 manifold and new knock sensors tomorrow, I'll be changing the fluid.
My buddy seems to think it's axle bearings too.
Old 02-09-2008, 01:11 AM
duece_bigalo01's Avatar
I have the zextel diff and when mine started to make that noise it turned out to be the heilcal gears in the diff. I had it rebuilt and waiting to purchase my 9 inch now.
Old 02-09-2008, 10:15 AM
Wsteun's Avatar
I'm not entirely worried about it. Granted I just bought the car, I'm looking for a 3.42 rear end anyway.
Old 02-09-2008, 10:21 AM
pooter99ta's Avatar
mine makes the same noise. the zexel torsions are known for doing that with wear.
Old 02-09-2008, 12:59 PM
Jawsgear's Avatar
SAounds like a worn positraction. Try adding a lsd additive to see if it calms down.
Jeff
Old 01-11-2009, 10:02 PM
LS1Adam84's Avatar
Rear is going out mine did that like a ratcheting clunk around turns finally it just ate the big one. Replaced it with a used 10 bolt with 3:42's, problem solved.
Old 01-12-2009, 04:01 PM
NightMoves's Avatar
Jeff
Is it wise to also change the positrac clutches when doing a gear change?
Quick Reply: 10 bolt groaning while turning
