How much hp will a stock driveshaft handle?
I'll be ordering a 9 inch soon, but wondering if i'll need a new driveshaft too or if i'll be ok with the stock one. Any recommendations?
The car will have a 9 inch with 4.11 gears, running (as of right now) 275 m/t dr's. Suspension is basic lca's, phr, sfc's and also Qa1 shocks. My car put down 418hp on a mustang dyno.
I'm interested to know this also, but I'm pretty we'll both be needing a stronger drive shaft. I plan on getting a heavy duty one with my 9", 4.11 gears, MT Street Radials. We'll be able to launch from really high RPM's which will kill the stock drive shaft at 400+ torque. Of course my car has an aluminum drive shaft stock. I'm not sure about yours.
LS1TECH Sponsor
For the money, it's tough not to suggest a new driveshaft when you're doing a beefed up rear end. A $400 driveshaft can save you hundreds of extra dollars if you break the stocker and it tears the bottom of the car up - or worse.
Buy a new driveshaft and sell your stocker to an LT1 guy.
we need to meet up some time.
i have friend who broke them on street tires. i was launching mine on slick and it never broke. i did have a viberation at speed thoe the front u-joint and rubber dampaner was going out. i bought a PST it took care of my viberation and it wont break
Well just to give you an idea, before the mods: Stock HP, Rear, Clutch...... everything 100% stock on a set of BFG KDW's. I got the tires hot enough and launched on some new blacktop 3 blocks from my house. Peeled it like an apple and ended up pushing it the whole way home. So yes, its not the HP.....its all how you hook my friend.
http://www.exoticperformanceplus.com....html?item=541
Ok, i'm going to order one but have a issue. I ordered my rear with a 1350 yoke but the new 1350 u joint wouldn't fit. Luckily I had another stocker and it fit like a glove, so does that mean I have a 1310 yoke? Trying to figure out for ordering purposes... Thanks.
That is exactly why we sell so many of the PST 3.5" alum driveshafts, rated at 1000 hp. Lifetime warranty and 10 years on the u joints. Bob
Also, it says that the u-joint won't mate up to the 10bolt.. What will it mate up to without a conversion kit from Napa? And any idea how much the conversion kit is?
Thanks
Addison
