whats the cheaper way to go about a rear end?
Old 02-29-2008, 10:25 AM
nobird8991's Avatar
Default whats the cheaper way to go about a rear end?
i wanna replace my rear end and i don't wanna spend an arm and a leg doing it. whats the cheaper and better way to go about it? can you find anything in a junkyard thats worth building? how about a built ten bolt if i can get one for cheap is it worth it? i am thinking about getting one for a good deal so i'd go that way
Old 02-29-2008, 10:39 AM
99blancoSS's Avatar
buy a used one already setup for an fbody
Old 02-29-2008, 11:16 AM
BIG_MIKE2005's Avatar
^^That or buy a Moser 9" Housing/Axle kit for $1000 shipped & then build your own center section. You can buy all the pieces off ebay new for around $800 & thats with a Strange "S" case & posi. Can be cheaper if you go spool.
Old 02-29-2008, 11:19 AM
nobird8991's Avatar
i've been told i shouldn't go 9 inch just because of the substantial power loss. i won't be over 400rwhp this year unless i spray it and thats not even a for sure thing. i just wanna be able to put some DR's on it and get that thing out of the hole hard
Old 02-29-2008, 11:21 AM
99blancoSS's Avatar
Yep the 9 eats about 20 but you aint gonna break it.
Old 02-29-2008, 11:31 AM
Man it really doesn't eat up much more than a 12-bolt & if your a 6-speed you'll praise the 9" later when it doesn't take a dump on you. I would never suggest goin with a 12-bolt in a 6-speed if your gonna ever put full slicks on it. It has been done but lots of guys making decent power & running a 6-speed have broke 12-bolts. An auto car is alot easier on the rears in these cars than a 6-speed. So you also need to factor that into it.
Old 02-29-2008, 11:33 AM
keliente's Avatar
There is nothing cheap and easy. If there was something you could get out of a junkyard and build, aftermarket rear ends would not fly off the shelves like they do. If it's cheap it ain't reliable and if it's reliable it ain't cheap.
1. Buy a new 9 inch, 12 bolt, or S60. Cost $2,200+. Never worry about rear end again.
2. Buy a used 9 inch, 12 bolt, or S60. Cost $1,500+. Never worry about rear end again.
3. Build your 10 bolt. Build it about three more times as it is not a matter of "if" but "when" it will break. Continually. Then realize you've wasted money rebuilding something inferior and should have just saved up for a real rear end before going to the track.
Old 02-29-2008, 11:41 AM
99blancoSS's Avatar
Words of wisdom right there ^^^
Old 02-29-2008, 06:39 PM
john563's Avatar
Dont know if its quite that high,but any way I just got my gmhightech mag in.They had a tech artical about rear ends. They tested two cars.One with a dana 60 and the other with a moser m9. The dana had a 3.5% loss in hp and the m9 had 1%. the camaro that switch to the dana use to have 342 gears and use to put down 421rwhp 390rwt.After the dana 60 with 3:73 gears it put down 398/376. the trans am with 342 gear put down 441rwhp432rwt and with the moser with 370 gear it put down436/428
Old 03-01-2008, 04:14 AM
EPP
EPP's Avatar
http://www.exoticperformanceplus.com...html?item=1116
Moser 9 inch housing/axle package. Bob
Old 03-01-2008, 07:58 AM
99blancoSS's Avatar
There is a thread on here where someone records the loss of just adding a 9" on the dyno. droped 19hp
Old 03-01-2008, 08:20 AM
Internet Mechanic
BlackScreaminMachine's Avatar
A built Ford 8.8
Old 03-01-2008, 09:19 AM
daniel6718's Avatar
ford 8.8 but you rent saving a ton...not enough to make it worth it imo
ive seen a guy locally keep stock gear in his 10 bolt...put in an eaton posi(posis break in them a lot) then put moser axles(they break next) and hes been doing 1.38 60' consistantly at 3700+
personally id rather get a rearnend im not goana worry about breaking
Old 03-01-2008, 12:37 PM
RAGENZ28's Avatar
Adding more gear also tends to produce less hp on the dyno.
And from my experience going from a 10 bolt to a 9' drops more than 1% hp
Old 03-01-2008, 01:14 PM
99blancoSS's Avatar
Its documented on a dyno guys. There are so many variables to dyno numbers that unless you do your testing same day you cant really use the info.. unless you control and match all those variables.
Now I'm not saying you guys are wrong. I'm saying it was done by someone here and they dyno tested it to 19 hp loss and documented it. I've seen the thread, I'll look for it and post the link. Maybe there is something wrong with it?
9" has a 90% efficiency. 12-bolt has a 93% efficiency. A 10 bolt is hair more efficient due to a little less rotating mass. When it is all said and done, the differences are negligible.
still looking
Old 03-01-2008, 03:21 PM
john563's Avatar
what size gear? I think gears play a big part on numbers eaten up(not that it matters)on a dyno
Old 03-01-2008, 03:40 PM
99blancoSS's Avatar
thats why I'm trying to find it. It had all the details that I cant remember..lol
Old 03-01-2008, 03:45 PM
Kleeborp the Moderator™
MeentSS02's Avatar
Originally Posted by BlackScreaminMachine
A built Ford 8.8
Only if you can find someone that can weld cast iron worth a damn to make it work with a torque arm.
Old 03-01-2008, 05:55 PM
Mike2kZ's Avatar
"cheaper and better" This is hardly ever the case.
What Keliente says is gospel. Do it right the first time and don't worry about it.
Old 03-01-2008, 06:00 PM
Websy21's Avatar
M6, get a new or use moser 9'' end of story
A4 get a used or used 12 bolt up to about 650-700rwhp but I'd still get the 9''
Quick Reply: whats the cheaper way to go about a rear end?
