knocking on launch
Old 03-01-2008, 02:05 AM
billybob1142's Avatar
Default knocking on launch
So the past few times i have been at the track i heard a knocking noise when i took off and i didnt really make notice of it. Well tonight i was at the track and when i launched i heard the noise a little bit more, almost like poping, but once i got off the line it wouldnt do it anymore. Has anyone ever had this same problem?
Old 03-02-2008, 01:22 AM
anyone?
Old 03-02-2008, 10:16 AM
blue98Z's Avatar
I have and it was the torque arm hitting the bottom of the car. You might look under the car in the tunnel area above the torque arm to see if that might be it.
Old 03-02-2008, 10:47 AM
EPP
EPP's Avatar
Check this out. Bob
http://www.exoticperformanceplus.com...php?service=58
Old 03-02-2008, 01:42 PM
thanks guys. Im about to put it up on ramps and check it out.
Old 03-02-2008, 02:06 PM
meandmyls1's Avatar
Originally Posted by Exotic Performance Plus
Just curious, if this 50+ year old customer with the bent torque arm does not do any hard launches then why did he get his axle tubes welded to the center section?
Old 03-04-2008, 10:45 PM
So last night i was under my car and looked at everything. Torque arm seemed fine. So i checked my transmission mount, and the front tq arm mount. The tq arm mount had a split in the rubber so im wondering if its moving when i launch. Also on the driver side the rubber on my bump stop is gone and on the passenger side the bump stop is half gone. I wouldnt think my rear would drop down that far so i dunno if thats the problem.
Old 03-05-2008, 03:59 AM
EPP
EPP's Avatar
Smile
He had us install a Moser 12 bolt in his car, as he did not trust the 10 bolt. Bob
Old 03-05-2008, 04:00 AM
EPP
EPP's Avatar
Question
Stick a pry bar under the trans crossmember and see if the tranny mount is shot. Bob
Old 03-05-2008, 04:56 AM
wrd1972's Avatar
Bent the torque arm like that and he claimed to have never lauunched it hard. Gotta call BS there. Someone that never launched the car and wants the 10 bolt replaced due to lack of trust. That dont sound right. Clearly he was not honest or did not provide the rest of the story to you Bob.
Old 03-05-2008, 12:30 PM
thanks bob ill get back under it tonight and check.
Old 03-06-2008, 01:02 AM
anyone else have any suggestions?
