relocation bracket help
Old 03-11-2008, 07:30 PM
snugans310's Avatar
Default relocation bracket help
what relocation crackets will fit a 12 moser i just got some hotchkis lower control arms and i want to get them on but i want the relocation brackets but dont know what to get for the moser
Old 03-11-2008, 07:36 PM
GregWS6&z28's Avatar
UMI probably. lookem up
Old 03-11-2008, 07:40 PM
snugans310's Avatar
the bolt on or weld in
Old 03-11-2008, 07:43 PM
both should work. i think the dimensions for the lca is same for the 12 bolt as the 10
Old 03-11-2008, 07:48 PM
EPP
EPP's Avatar
We use the BMR CAB001 weld on relocation brackets. A little grinding needs to be done to them to make them fit, but nothing trick or exotic. Bob
Old 03-11-2008, 08:09 PM
snugans310's Avatar
but im trying to do all this at home
Old 03-11-2008, 08:10 PM
do you have an angle grinder? definitely get the bolt in then
Old 03-12-2008, 03:46 AM
2002gt's Avatar
Wink
Check out Spohn website.
They have brackets that are for a 12 bolt rear. Thats the way I went.
You don`t have to cut them like bmr`s and umi`s.
Old 03-13-2008, 07:43 PM
snugans310's Avatar
got the spohn's thanks for the help
