Yes Its Another Help Me Decide Thread!
Old 03-12-2008, 11:09 PM
383lt1impala's Avatar
Default Yes Its Another Help Me Decide Thread!
well soon ill be needing a good rear for my camaro its going to have about 1000rwhp tru a 400 with about a 4500stall and a t/b of course and i know i should get a 9inch but. i have no idea tru which vendor or if i should get a spool or tru track. and i am going to drive it on the street occtionally. and if this helps i am going to run a 10.5 dr tire. and should i get the abs my z28 is a 4 chanel but i wont be needing the asr also i was told i should get a 35 spline or better. well thats pretty much all the info. thanks for the help!
Old 03-13-2008, 12:41 AM
CW00BlackTA's Avatar
TruTrac won't hold up to that much power if you're hooking it up. A locker or spool is in your future.
Old 03-13-2008, 10:01 AM
LS1TECH Sponsor
Steve Burger's Avatar
I can work with you. Our Fabricated 9" just went 7.4x in Brady and Madma's car. We can build about anything you want. Send me a PM with your number and we can talk over your needs.
Old 05-19-2008, 01:55 PM
ok sponsers i am alot closer on ordering a 9 inch and i would like 40 sline axels (might as well go big) and if its possible a detroit locker if not a l.w. spool narrowed 3 inches on each side, 411 pro gears, no tcs or abs, long ARP wheel studs, with and without a aluminum pro nodular casing, red powdercoating, drain and fill plug, torque arm, th400 crossmember, i will use my stock brakes, good axels, drag sway bar. remind me of anything i 4got. so please sonsors pm me a price with shipping and anyother options i might half of forgotten and how much warranty etc etc. thanks in advanced. also i would perfer a fabed houing with a backbrace. not the older style.
Old 05-20-2008, 05:16 AM
EPP
EPP's Avatar
Thumbs up
You can spec it out right here, just the way you want it.
http://www.exoticperformanceplus.com...html?item=1324
An M9 is ready to ship just two days after the order is received! Bob
Old 05-20-2008, 08:43 PM
how much for shipping to the 92316 and what kind of warranty does it come with?
Old 05-21-2008, 05:10 AM
EPP
EPP's Avatar
Thumbs up
Shipping is free. Because of the potential for abuse it is hard to warranty a rear-end, but if something immediately goes wrong with a new Moser rear, and it is not an installation error, Moser will take care of it. Bob
Old 05-22-2008, 10:27 AM
LS1TECH Sponsor
We can set you up with a bullet proof rear. Send me PM with a number and we can talk over otions.
Old 05-22-2008, 10:52 AM
Jawsgear's Avatar
I assume you are aware that a pro series gear cannot be driven on the street. It is a softer 9310 steel and will wear out really fast. They are made for drag racing only. If you plan on driving it on the street you need to buy an 8620 steel gear, which is made for street and race applications. PM Sent.
Jeff
