Moser 9" oil change
Moser 9" oil change
How long after initial break in before you changed out the gear lube. Also after the initial is it ok to use synthetic or stick with normal dino oil
the gear oil you will use depends on which differential you have. you must abide by the factory recommendations or your diff wont function properly.
its late, im drunk and dont care about spelling
