B&M deep pan helps alot!
Re: B&M deep pan helps alot!
Ive thought about getting the deeper tranny pan. I didnt know if it would help much or not. But a 30 degree drop is a nice drop in temperature with just the deeper pan. I might check into it...
i have a cooler also.. i forget the size since its been like 3 years since i put it on the car. But do to the location of the cooler it never helped much. The FTRA was in the way so i couldnt mount it there.
but temps were in the 190's with the cooler.. and now 160's with deep pan!
I used AMS oil also
I used AMS oil also
Deep pans help, but let's see what your summer temps look like before you jump to conclusions about a 30* drop. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
BTW, the cooling comes from more than just having to heat up more oil. The pan has cooling fins to help disapate the heat. That's why I like the aftermarket pans better than a truck pan.
LS1Tech Administrator
Received 1,492 Likes
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Ragtop 99:
<strong>
BTW, the cooling comes from more than just having to heat up more oil. The pan has cooling fins to help disapate the heat. That's why I like the aftermarket pans better than a truck pan. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Aftermarket pans tend to not seal as well as the GM pans in some cases, also they hang a bit lower. Not to mention the higher cost <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
<strong>
I know my trans temps before the deep pan were like 190ish
after deep pan they dropped to 160 <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
just a FYI post <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
I noticed a nice drop in trans temp going to the GM deep truck pan as well. Dropped them about 15-20 degrees on averge. The B&M pan is even bigger and has cooling fins, but the new tranny I bought came with the deep GM pan so I'm just using that <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
