Will 4.10s help me out???
Well today i went out to play this was the first time ive gotten to do ne thing since the cam install. I have to say im kind of disappointed, I ran another z28 with unknown mods other than he was m6 as well. He was half a car ahead when he punched it so i had to catch up. Then I ran a 347 stroked s/c stang running 8lbs and I still have stock gears on my car and the SOB wont go in 3rd so i have some more work to do. Is this a normal outcome for these races or is my car a turd with the ms4? and would some 4.10s greatly help my cause and change the outcome?
heres the link to the vids:
https://ls1tech.com/forums/multimedia-exchange/910841-me-vs-z28-347-stroked-s-c-stang.html
Kleeborp the Moderator™
A cam does not a fast car make...you need to make sure your install was fine (as in you degreed in the cam, double checked everything including proper pushrod length), you need to make sure the tune is spot on, etc. etc. There are too many things to point to one thing, but the 4.10s would probably help some. Cams that large are usually very soggy on the low end (the one MS3 car I've driven was really soft until it got up in the RPMs), so I'm not surprised at the outcome at all. The 4.10s will help mask the sogginess...
EDIT: Also if i hadnt installed the cam properly with that large of a cam on stock heads I would def have bent rods maybe even floated valves even just after start up and I only have a mail order tune from tsp right now.
Racing from a roll like you did and starting from 4k rpms, you should be just nicely getting into the powerband with that cam. Keep in mind that guy has forced induction whereas you seem to be n/a. Also those notchback 'stangs are very light, so that guy had a couple of advantages right there. FWIW, u might as well get u some 4:10s so u can get your rpms up quicker to take advantage of that cam. I have a MS3, and am in the same boat as you. The 4:10s are going in mine when I get that "bonus" tax refund that we are all supposedly getting.
1 Post
Sounds like you need another ride.
