help a moron please
Old 05-18-2008, 07:16 PM
roscoe545's Avatar
Default help a moron please
i've heard a million times how easy it is to take out the axel c clips on a 10 bolt. for the life of me i cant get the ****ers out. it seems like tere isnt enough clearance for the clip to slide past the small diff gear. any help would be much appreciated and if you want to call me a moron, go right ahead lol.
Old 05-18-2008, 08:36 PM
EPP
EPP's Avatar
Pushing in on the axles from the end where the wheels bolt on, will help to give you clearance to remove the c clips. Bob
Old 05-18-2008, 09:10 PM
roscoe545's Avatar
thanks bob, ill give it a shot again tomorrow. this is bob from wisonsin gettin ready for the m9. thanks for all the help so far and i'm sure ill have some more questions for ya once i get it. Kudos for a great guy and even on a sunday he's on ls1tech!!!
Old 05-18-2008, 09:15 PM
EPP
EPP's Avatar
Thumbs up
Thanks, I appreciate it Bob!
Bob
Old 05-18-2008, 09:38 PM
thebulgd's Avatar
theres some black ABS sensors or some **** between the brake backing plate and the plate on the axle that will stop you from being able to push the axle in far enough for the C-clip to drop out. easy to remove. I could be wrong, though this caused me problems the first time I removed my axles.
Old 05-18-2008, 09:39 PM
alamantia's Avatar
yeah, wat he said, on a 4 channel rear (traction control) you have to remove the ABS sensores to push the axles in far enough
Old 05-18-2008, 11:11 PM
99mongooSS's Avatar
remove the wheel speed sensor from the end of the axle housing. it should get you about a 1/16 more of an inch which will let the c clip come out.
Old 05-19-2008, 12:32 AM
roscoe545's Avatar
i actually found it in the FAQ sticky a little while ago but thanks for the quick responses guys. hopefully i can tackle the beast tomorrow. thanks again
Old 05-19-2008, 12:34 AM
Fotis's Avatar
is the car jacked up from the rear differential or the frame?
Old 05-19-2008, 12:41 AM
roscoe545's Avatar
its out of the car layin on the garage floor
Old 05-19-2008, 12:04 PM
roscoe545's Avatar
got em. it literally took 20 seconds after i pulled out the sensors, THANKS GUYS
