9" Breather.
Old 08-18-2008, 10:26 PM
blazin's Avatar
Default 9" Breather.
I totally overlooked the breather situation on my car when I installed the 9". I was wondering what everyone is doing. I have read a couple posts about vaccum line about 18 inches long. I was wondering if a check type valve like gm used would be neccessary? If so anyone have a part number. Thanks ALot!
Old 08-19-2008, 12:43 PM
jmm98LS1's Avatar
I just used 5/16" rubber hose, ~12" long and left the end open. Works fine, no leaks anywhere.
Old 08-19-2008, 08:02 PM
_JB_'s Avatar
I bought a PCV valve that screwed into the rearend and added some vacuum hose.
Old 08-20-2008, 08:02 AM
ynkssws6's Avatar
hose onto the rear and a breather filter at the end so far so good
Old 08-20-2008, 08:45 AM
blazin's Avatar
Where did you pick up the breather filter at?
Old 08-20-2008, 05:11 PM
Loadre's Avatar
Ran some hose up along the upper panhard towards the passenger side, then went about a foot towards the rear bumper. Just zip tied a shop towel around the end.
Old 08-21-2008, 04:59 AM
EPP
EPP's Avatar
You don't need a check valve or anything other than about 2 ft of vacuum line. We zip tie it up to the driver side gas tank strap. Bob
Old 08-21-2008, 08:22 AM
blazin's Avatar
Thats good to hear!
Old 08-21-2008, 09:29 AM
ynkssws6's Avatar
I believe it's a K&N valve cover breather, picked it up at a local place. I liked it cause you could put a screw into the top therefore being able to mount it out of the way.
Old 08-21-2008, 10:32 AM
caddobass's Avatar
I would not leave the end of the hose open. I had mud wasp build in vent hose and cause a pinion seal leak. I know that sounds stange, but it did happen to me a couple of months ago. I am looking for some type of check valve to put in the end of the vent hose. Anyone have a good idea???????
