View Poll Results: 373 or 411's?
373
13
30.95%
411
29
69.05%
Voters: 42. You may not vote on this poll
373's or 410's
373's or 410's
I have an 2000 camaro SS with an M6. Slp cold air kit, and catback is about all the mods I have done as of right now. Still have the stock 10 bolt rear end. Starting to make a funny noise and Im wanting to do the rearend. This a daily driver and will see no strip time. Only some tireburning street racing from time to time. Wondering what gears to go with? Also what is a decent installation fee?
If you never plan on taking it to the track, or running sticky tires ... I would say the 4.10s. They are great for M6s, but since they are thinner then stock they have a higher failure rate on 10-bolts.
If you ever plan to entertain the thought of going to the track or getting sticky tires, I would recommend the 3.73s.
Simple!
Simple!
I just got the Motive 3.73 gears and I am verry satisfied with them. Woke my car up and it is a difference now.
4.10's just installed yesterday, nice bump from the 3.42's, you really feel the torque! I paid a little over $400 for the install.....labor,oils, slip additive and a crush sleeve, I supplied the gears, install kit, and TA diff cover. Some may say this is too much, but these guys are good. Go with someone who has a good rep, cause you'll get what you pay for. Go with Motive or GM gears.
I'd go 3.73's for a street car, especially if you won't take it to the track. And since it's a daily driver, even more reason for 3.73's, better highway gas mileage. I love my 3.73's, they're perfect for the street, and stronger than 4.10's.
Looking into the same swap for my 2000 WS6 with the M6. I was trying to decide between the Motive 3.90's or the Motive 4.10's. but leaning towards the 4.10's.
My WS6 only gets driven once in a while and I will take it to the track. I have started to have trouble with the rearend leaking fluid, so i figured while I was back there i would like to do the swap. Running Goodyear Eagle F1 Supercar EMT 275/40/18 on 10.5 wide rims. Only cold air intake and flowmaster exhaust otherwise. Any opinions to make my decision easier? i am getting the impression 4.10s are the right choice.
4.10s are the way to go. got mine installed last year and havent had a problem since. just dont stick a sticky tire on and you should be good. ive been to the track and my rear hasnt blown yet so its all good. 3.73s are a waste if your going to spend the same amount of money for the set and install... why not make the car a little bit faster.
