Play in my Pinion!!
Old 09-19-2008, 06:48 PM
Ilikeppie's Avatar
Question Play in my Pinion!! VIDEO!!!!
so i have been getting a "rattle" from under the car and i figured it was probably the exhaust or something stupid however today i got it off the ground and was checking it out and found that my pinion has about a quarter inch of play in it and the seal is leaking now!! so can i just replace the pinion bearing and seal and fix it that way or is it gonna take a complete overhaul oh and this is a new rear with about 15,000 miles on it so im hoping everything else is still good
Old 09-19-2008, 08:13 PM
Black02SLPSS's Avatar
I would say your gonna need a complete overhaul. Im gonna venture a guess and say your crush sleeve is toast. Oh and your bearings are probably toast too. But i would say the ring gear and the pinion may still be good. I would think those would have the best chance of surviving.
Old 09-19-2008, 08:31 PM
Ilikeppie's Avatar
yeah this is kind of what i was thinking if i go in and put new bearings in and what not am i gonna have to measure backlash and what not?
Old 09-20-2008, 10:17 AM
LS1Formulation's Avatar
Yes, you're going to have to completely re-setup your ring and pinion. No way around it.
Old 09-20-2008, 06:23 PM
Ilikeppie's Avatar
is there any way i could just replace the front pinion bearing and seal as a temp fix to get me by for another week or two?
Old 09-20-2008, 07:27 PM
SS1875's Avatar
Maybe but you run the risk of more damage then there already is. At this point you might be able to salvage some parts...doubtful but possibly.
Old 09-20-2008, 07:41 PM
Ilikeppie's Avatar
yeah but after a week if the rear end catastrophically fails then it will be a good excuse to upgrade this winter to a moser
Old 09-20-2008, 08:10 PM
SS1875's Avatar
Very true but consider more options than a Moser...plenty of nice setups out there. S60, FAB 9", ETC.
Old 09-20-2008, 08:13 PM
Ilikeppie's Avatar
yeah i havnt really studied up on rearends too much i dont really know what would be the best
Old 09-20-2008, 08:46 PM
SS1875's Avatar
Looks like you have quite a few mods done currently. My advice would be to think about what else you might do to the car that could cause stress to the rearend.
For an example, I had a Moser 12 bolt N/A car DD/some track time. I decided that it would be seeing more upgrades, on of which is Nitrous. Being that my car is an M6 I didn't want to have an issue with stress on the 12 bolt housing so I had a Midwest Chassis Fab9" built...in hopes it will be the last one I will ever need...strength wise for my setup.
Old 09-22-2008, 10:36 PM
Ilikeppie's Avatar
hmm well its gonna be modded a lot more before its said and done with but right now nothing crazy but here is a update on the axle i can not find anything that looks bad there were some metal shards on the magnet but other than that and play in the pinion i can not see anything that looks bad the bearings look great so whats going on with this rear end why did the pinion get play in it and what could these metal shards be from?
Old 09-22-2008, 10:58 PM
SS1875's Avatar
Good question...broken shims of some sort??....I couldn't really tell you, never seen anything like it before.
Old 09-22-2008, 11:43 PM
Ilikeppie's Avatar
i am completely lost with this because everything looks in good condition i was thinking that metal was a shim as well but where would it have come from would have this caused the play in the pinion?
Old 09-23-2008, 10:57 AM
ajrothm's Avatar
Piece of the crush sleeve or something? Something obviously is causing the slop. My 10 bolt with 4.10s was the same way, thats why I pulled it out. I didn't have as much pinion slop as yours but it was pretty close, atleast 1/8" of movement in any direction. I have a feeling the shop that did the gear install used the same crush sleeve on mine and just tighted the F outta the nut..... I just retired the 10 bolt.
Old 09-23-2008, 11:12 AM
Ilikeppie's Avatar
i think the crush sleeve is all there look at the pic of the pinion its on the shaft could it be some sort of a shim behind the back bearing on the pinion
Old 09-23-2008, 01:37 PM
FirstYrLS1Z's Avatar
?pinion shim fragments from being 'hammered' in and out?
Old 09-23-2008, 07:06 PM
Ilikeppie's Avatar
ok so here is what i think is going on the shim behind the back bearing on the pinion is what the fragments are and without it there the back bearing backed up causing play in the pinion
Old 09-24-2008, 11:49 AM
ERVNZ28's Avatar
"Ilikeppie" I would be thankful if u would let me know when you find something out about your rear....my 4:10's 10bolt has play in the pinion from the pinion nut coming loose...mine now whines badly but used to grind until i tightened the pinion nut. It now whines miserably but doesn't grind/etc. My Z goes to the shop 2nite hopefully just needing seals,bearings, re-setup/dialed in gears
Old 09-24-2008, 06:48 PM
Ilikeppie's Avatar
from what i have learned i would say that beings your pinion nut was loose while the pinion was loose it made a new pattern in the gears causing it to whine you will probably need a new gear set as well
